What Speaker Cable to Buy??
hglass
hglass Posts: 7
Im looking for a good quality speaker cable. I will be needing it for my left, right and center speakers. They are to be bi-wired. I dont want to spend more than $600 a run. Thats $1800 total. Any ideas??:confused:
Post edited by hglass on
  • Conradicles
    Conradicles Posts: 6,343
    edited October 2009
    Monster all the way.
  • Face
    Face Posts: 14,340
    edited October 2009
    What does the rest of your setup consist of?
  • PSOVLSK
    PSOVLSK Posts: 5,381
    edited October 2009
    Keiko wrote: »
    Blue Jeans Cable Canare 4S11 Cable, Star Quad would be an excellent starting point since you're using a bi-wired configuration. Face brought up a valid question, and there are other options for "good quality" cable available to you. Considering the budget.
    http://bluejeanscable.com/store/speaker/index.htm
    +1. I use the BJC Ten in my HT, but for a bi-wire setup the 4S11 looks like a great choice.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    I don't think you need to spend $600/length but i would agree the Canare is a good start! I have some coming this week so i can make my own $1,000,000,000,000.00 cable's :D I already have the heat shrink, techflex and silver solder :) Just need to decide if i'm going to terminate the end's or tin the bare wire :confused:
    Right now i'm using some Rocketfish 16g i got with my speaker's from Futuresh|t to wire my whole system and it souind's fine :o
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • fbm211
    fbm211 Posts: 1,488
    edited October 2009
    You can try these with your budget.>http://www.audiogon.com/cgi-bin/cls.pl?cablspkr&1260894028&/Morrow-audio-sp4
    With a 60- day audition/refund policy you cant go wrong.If you dont like em or want to try something else just return them and get a refund. You can get them biwired too.
    Check out the link to more info....
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • anhchungdoan
    anhchungdoan Posts: 760
    edited October 2009
    hglass wrote: »
    I do not know what kind of gear you are using but IMHO, For Audio application , BETTER CABLES SILVER SERPENT ( very clean and clear) or better yet my favourite KIMBER KABLE 8 TC ( nice mid/ smooth high ). You have to spend a lot more money to beat the 8 TC. But why? For my H/T application, Monster 14 gauge all the way:D
  • PSOVLSK
    edited October 2009
    I promise I'm not being a jerk, but I thought Monster didn't publish the gauge of their speaker cable.
  • danz1906
    danz1906 Posts: 5,144
    edited October 2009
    Welcome to the Club!
    Try Audioquest
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • anhchungdoan
    edited October 2009
    PSOVLSK wrote: »
    No, you are not a jerk. I understand how some people hate Monster for just being "Monster". Yeah, I bought the big spoon @ $129.00@ 50 feet at Fry's at I know that it is 14 gauge using my connector/ cable Crimp that I bought @ RatShack.:D
    I do not believe I would hear that much different with the ambience of explosions or rocket flying over my head by using more expensive ICs or speaker cables but we all have our all opinion or experience.
  • anhchungdoan
    edited October 2009
    PSOVLSK wrote: »
    If you are not familiar with different size of the copper, there is a easy way to identify the cable gauge. After stripping of the insulation, you can use the Butt-on-crimp to measure the actual gauge of the copper strands. The Butt-on-crimp connectors are color code as follows: RED for 22-18 gauge, BLUE for 16-14 gauge and Yellow for 10-12 gauge. Also the connector crimp ( abt $9.00) also have different gauge using to strip the insulation.
    You should try to make your own speaker connectors. It's fun and save a lot of money. Why pay $20.00 for a pair of banana plugs or lugs space.
  • Conradicles
    edited October 2009
    or lugs space.
    What is that?
  • anhchungdoan
    edited October 2009
    What is that?
    You've got me. It's lug space not space lugs. My fault. Blame it on Dyslexia :D
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited October 2009
    I use monster cable speaker wire from best buy. "ya ya it is monster cable" Works just fine unless you are planning on pushing like over 250 watts to your speakers this stuff works just fine.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    It all sounds the same. :rolleyes:
  • sTiLlLeArNiNg
    edited October 2009
    xcapri79 wrote: »
    Do you have your flame-suit on?
    Some don't like store bought 16 AWG Cu even though it does work fine.
    lol I don't need a flame suit :o
    Media Room 7.1
    HTPC
  • hglass
    hglass Posts: 7
    edited October 2009
    Face wrote: »
    I have a Classe amp model # CAV 180. B&W speakers 803 and a Meridian 861 A/V
  • anhchungdoan
    edited October 2009
    hglass wrote: »
    Nice gear. May I ask about your ICs and what do you like abt them and what do you not like abt them.
    I've just received a reply from Better Cable people. As my request, they will make a shorter run abt 2 meter length ( 6.56 feet) with BFA gold termination. Single 2 meter is run is $ 64.98 and bi-wire 2 meter run is $84.98. They will terminated with either BFA gold or spade-gold grip and the connectors will look different than the ones on their web-site.
    Do not go too cheap on Classe or Krell since you will do them no justice. Wire is not just wire.
    I have owned the Silver Serpent before and loved it but when I switched from Krell 400xi to Bryston 4Bsst/ BP26 pre, I have the Silver Serpent sold in less than a week and replaced them with the more expensive Audioquest.
    For budget cables, I highly recommended the BetterCables Silver Serpent. Good luck.
  • beardog03
    beardog03 Posts: 5,550
    edited October 2009
    I would suggest you take a look here....www.audioadvisor.com and check out the AudioQuest Slate speaker cables...
    Great place to start
    quality cable....great price
    no affil.
    Just my .02
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Face
    Face Posts: 14,340
    edited October 2009
    MIT Shotguns, without a doubt. Better bass, imaging, and a larger soundstage than "regular" cable. The matching interconnects will also make a substantial difference.
  • beardog03
    edited October 2009
    if you have the budget...
    There is NO equal to MIT ...IMO
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • anhchungdoan
    edited October 2009
    beardog03 wrote: »
    If no budget limitation, yeah the sky is the limit. Now we're talking ( MIT) real hi-end stuff . :D
    F1nut Posts: 51,774
    edited October 2009
    hglass wrote: »
    Yeah, you should be looking at MIT.
  • CoolJazz
    CoolJazz Posts: 572
    edited October 2009
    ...unless you are planning on pushing like over 250 watts to your speakers this stuff works just fine.
    Quality cable isn't necessarily about pushing high wattage at all! You are actually much more likely to hear differences on low wattage/high efficiency systems. This is because in those systems you're typically using single output devices. This avoids the blurring of multiiple parallel outputs that can never be exactly the same on transients.
    CoolJazz
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
