few questions about sub woofer cable
mr2sw21
I just bought a set of sub woofer cable but it not as good as my set up before (with speakers wire with front left and right in then left right out to the front speakers) the set up before front Large set up the sub woofer I can feel it has deeper and louder feeling. Now I just connect the sub woofer cable and set all the speakers to small with 100 cross. now the sub all of a sudden feels nothing almost.
Did I set something wrong?
By the way what is the Y cable for? should I use it as well? Or I don't need it? If I don't need that that when will one use it?
Thanks,
Thanks,
Post edited by mr2sw21 on
Y cable is for 2 subs. Try setting Xover to 120 maybe, increase sub volume......
I suppose that before your AVR had nothing to do with bass management and now in LFE it does.
ps. make sure LFE is ON -
Subscribed.
I have this problem with my AVR as well.
OP, what AVR do you have?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
yamaha Z7
I have actually just set it up with the Mic. again. I am not 100% sure if I have turn the LFE on or not good point. Thanks,
P.S. does that matter (at the sub) the crossover tune to (120-60) or after I plug with sub cable that doesn't function any more? -
from what I have read, IF you are using the crossover in the AVR, then you want to set the crossover on the sub to "full blast" whatever that relates to on your sub.
The AVR is already directing the the freq's where they need to go.
I know once I did this I noticed a big difference (had the sub set at 100hz before)
Also, a "y" can also be used to feed signal to both channels on the sub. Depending on which sub you have, it might make a difference. -
Use mic to fine tune the equalizers (you've done that), but the rest of the settings do manually. All speakers to SMALL and LFE/BASS OUT to SUB, LFE to ON. Also check sub volume level in AVR
In my case sub xovers are disabled in LFE setup.
