Need help getting started with an Emotiva XPA-3
prstrings
prstrings Posts: 33
edited October 2009 in Electronics
I finally bought an XPA-3 to finally give my towers (RTi12) and center (CSi5) the power they need. The strange, and embarrassing, thing is that I don't really know what kind of cables I need to hook up my amp. Also, I would really appreciate any suggestions as to brand and price, but I would like to keep it pretty inexpensive (so long as there's not a marked trade off in sound quality).
Thanks in advance.
Post edited by prstrings on
  • danger boy
    danger boy Posts: 15,722
    edited October 2009
    the cables from your receiver to the amp is a standard RCA interconnect.. the same you would use for a CD player or tape player.. standard RCA cables.. the brand is up to you.
    PolkFest 2012, who's going>?
  • Sherardp
    Sherardp Posts: 8,038
    edited October 2009
    Start with these, mention to Frank you're a member of Club Polk and you will get a discount. Awesome guy to work with too.
    http://signalcable.com/analogtwo.html
  • prstrings
    prstrings Posts: 33
    edited October 2009
    xcapri79 wrote: »
    I'm curious as to what AVR you are using. Ensure that it has preamp outputs, otherwise you cannot connect to your XPA-3 amp.
    Make sure you use a good quality double shielded, gold-plated RCA connector stereo audio cable. Good quality doesn't have to be expensive either.
    I am using an Onkyo 805, so I'm good to go with the preouts. Admittedly, though, the first AVR I bought to go with the towers did not have preouts, so I had to upgrade to the 805 with an eye toward getting the amp. It took a little longer to get the amp than I anticipated, but I'm finally there.
    Thanks to Sherardp for the suggestion. I'm still looking for additional suggestions.
  • love2listen
    love2listen Posts: 172
    edited October 2009
    Blue Jeans Cables offers good IC's at a reasonable price and great customer service.
  • superjunior
    superjunior Posts: 1,632
    edited October 2009
    the xpa-3 is really touchy as to what ics you use. I used a set of monster cables and found the amp would go into protect mode and shut down. I than switched to mit avt 3s and problem went away and sound quality improved also. I wouldn't skimp on ics with this particular amp
    jr
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • dpowell
    dpowell Posts: 3,081
    edited October 2009
    I also have the signalcable analog II's recommended by sheardp and they are fantastic interconnects. They'll cost you a bit more than something you buy at Radio Shack (but really not that much more) but they are substantially better cables. You can start with cheap RCA cables just to get going but like a lot of us out here, you'll likely start wondering if you can hear a difference with better quality interconnects.
    There really isn't much to say with regards to connecting the pre to the pro. Just make sure both amps are unpllugged prior to connecting just to be safe. One pre-out to one connector on the XPA and plug your speakers into the XPA. Not sure if this is toogranular detail....just not exactly sure what advice you're seeking.
    enjoy the new amp!
  • prstrings
    prstrings Posts: 33
    edited October 2009
    So I have two votes for signalcable and another vote for Blue Jeans Cable. Any other suggestions?
    TIA
  • kevhed72
    kevhed72 Posts: 5,132
    edited October 2009
    I just bought a pair of Blue Jeans and so far so good...a bit cheaper than Signal I, but probably close in performance for acable
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2009
    Or you could use Monoprice for your cable needs. I have all BJC with with a Monoprice sub cable. Both get the job done, are easy to get on & off & didn't bankrupt me when purchased.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • superjunior
    edited October 2009
    not again...
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
