PowerVar conditioner for audio?
mmadden28
mmadden28 Posts: 4,283
edited October 2009 in Electronics
Anybody ever used them for audio?
I have a couple of these (PowerVar 6.0 (m/n# ABC60011W) rated 6A.) from work that were getting ditched-so they cost nada. :cool: They used to have the office servers or switches running through them. Probably new in '96.
Found these specs:
VA Rating 720
Frequenct 60 Hz / BTU/Hr. Output 147
T.H.D. % Added <1%
Load Surge Current @ 1/2 cycle: 215 amps
1 second: 102 amps / 10 seconds: 30 amps
Input Voltage 120 / Output Voltage 120
Output Current 6.0 amps
Efficiency 94%
Voltage Drop No Load to Full Load 6%
Complaince UL, cUL, RoHS
Shipping Weight 20 / Case Size 4.29x8.10x11.80
They work but at least one of them cuts out after a while (the circuit breaker in the power switch trips after about 30-40 mins of use). I opened the failing one up and noticed some charring under the resistor. I suppose I could fix that if its worth the effort.
Note the charring
And the same charred board flipped over--The resistor itself is a bit charred. I can't quite read the value
It's got a 720VA Torroidal transformer in there--If nothing else I should be able to put that to use somewhere right??/ Can't find any information on the transformer--Found the compay website, but nothing on this transformer.
Badger Transformer p/n#1TW601-11129-C
Doesn't look like there is much to it.
____________________
Pool: Atrium 60's/45's
