RT1000i left channel has no bass...
xj4094dg
xj4094dg Posts: 1,158
edited October 2009 in Vintage Speakers
The left channel suddenly has no bass. The green light is on and the sub does not engage whether set to on or auto. Did my amp take a dump? can I use an external amp for the sub? Help.
thanks
"The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
Post edited by xj4094dg on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    Check to see nothing came loose inside. The internal wiring is really basic if you take the plate amp off. Otherwise, inspect the amp itself once you take it out and see if anything burned out IE swollen caps/etc. There's no fuse on it unfortunately but hopefully it's just something that came disconnected.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • xj4094dg
    edited October 2009
    Thanks. That's first on the to do list for tomorrow.
  • xj4094dg
    edited October 2009
    Ok. I removed the amp plate, no strange looking caps or anything, it DOES have a fuse, fuse checks ok. powered-up, moved plate a little, sub came on, then went off. Cannot locate the loose connection! Damn!
    Finally got the sub to stay on for a while so started to replace the plate and as I'm tightening the plate to the back of the cabinet, the sub went off :mad: as I'm tightening the last screw...
    So I back off a little on the last screw and the sub comes back. I'm not completely happy but at least its working. What should I look for when I get back in there because its driving me nuts just knowing somethins is amiss.....
    Thanks.
  • kawizx9r
    edited October 2009
    At least it's not going bad!
    I should've mentioned looking for a loose connection/solder or something.
    -Freddy
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
