Burning .ISO to DVD
audiobliss
audiobliss Posts: 12,518
edited October 2009 in The Clubhouse
I have a few movies that I ripped to my computer from DVD before I came back to school this fall. Now I want to watch some of them away from my computer. How can I burn the .ISO's onto a DVD such that they'll be playable in a regular DVD player?
Thanks!!
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • John30_30
    John30_30 Posts: 1,024
    edited October 2009
    Download a copy of DVD Decrypter, it's free and burns iso's no prob. I saw somewhere also that Nero has finally released a vanilla version that's free. It's more versatile, but DVD Decrypter is very stable. What I'd recommend is that if the DVD media you get is rated at 16x burning speed, go no higher than 8.
    It's the recordable media that's tricky. Memorex? No matter what original manufacturer they get, Ridata, whoever, they're always the crappiest. Stay away from them.
    Also, make sure you uncheck the delete after successful burn box in DVD Decrypter if you want to keep the image on your drive.
  • vmaxer
    vmaxer Posts: 5,120
    edited October 2009
    I usually use the same software to burn the iso as I used to make the iso... Never had any problems.
    Do you still have it??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • audiobliss
    edited October 2009
    I used DVDFab to rip the DVD's, and I can't find anything in the program about burning.
    Will DVD Decrypter convert the .ISO to a file format so a regular DVD player will then be able to play it?
    And I researched DVD media a little bit before I bought any and ended up buying 100 TDK DVD+R's. I think I ended up with good stuff.
    Thanks!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Willow
    Willow Posts: 11,233
    edited October 2009
    You can use Alcohol 120% or even Nero. It's what we use. I prefer Alcohol over Nero for ISO. As long as your DVDP can handle newer formats, like DivX and such, you won't have an issue with playing ISO. on it.
    I think the PS3 can now play ISO as well.
  • bobman1235
    bobman1235 Posts: 10,822
    edited October 2009
    audiobliss wrote: »
    Are you using the latest version of DVDFab? 6.0.2.2 is the one I have, and on the left the very last option under "DVD to DVD" is "Write Data" which writes an ISO to a DVD (as a video DVD).
  • audiobliss
    edited October 2009
    bobman1235 wrote: »
    I'm using 6.0.4.0. That's awesome! Thanks so much! I'm burning a DVD now!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Pauly
    Pauly Posts: 4,519
    edited October 2009
    Windows 7 now has a built in image burner FYI
    Pauly
    Life without music would
  • nguyendot
    nguyendot Posts: 3,594
    edited October 2009
    Just use isorecorder.
    Main Surround -
  • audiobliss
    edited October 2009
    I wasted two DVD's trying to get DVDFab to work; both attempts failed. I'm now burning the .ISO with Alcohol 120.
    Thanks for the info, folks! Looks like I have a few more options to explore if Alcohol 120 doesn't work either, but I hope I don't have to go there.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited October 2009
    Alcohol 120 worked beautifully; seems like a good program.
    Thanks everyone!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • GMiller
    GMiller Posts: 127
    edited October 2009
    I've used ConvertXtoDVD with no problems. Works on a POS work DVD as well.
  • Willow
    edited October 2009
    audiobliss wrote: »
    Thanks everyone!!
    Like I said works every time for me too. Like someone else mentioned, be sure to uncheck delete file after burning, unless you want it deleted.
  • audiobliss
    edited October 2009
    All you guys raving about the greatness of Alcohol 120 (I agree, btw), do you PURCHASE the program or just keep using the trial version and wait for the timer when you start it up?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited October 2009
    Some of the movies I burned are a little glitchy toward the end, but will play alright after a while. Does that sound like slowing down the write speed might fix that?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • messiah
    messiah Posts: 1,790
    edited October 2009
    Just use convertxtodvd like Gmiller said. Converts basically anything, and gives you nice options as well. No need to slow down the write speed, I use the fastest and still works great.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • Sami
    Sami Posts: 4,634
    edited October 2009
    audiobliss wrote: »
    The outer layers of the disc are many times the critical areas. If slowing down the burn speed does not help (most likely it won't), reduce the size of the movie below 4GB.
  • messiah
    edited October 2009
    Anything under 4.7 will work with Convertxtodvd.
  • Sami
    Sami Posts: 4,634
    edited October 2009
    messiah wrote: »
    It's not the software you use, it's the burner and the media. Add in the DVD player you're playing and it's a big chance they all won't be compatible. Playing those DVD's from HTPC or streaming them into PS3 or similar device will have much better success rate.
