EL34, 300B and so forth?
kawizx9r
kawizx9r Posts: 5,150
edited October 2009 in Electronics
Well, as many of you know I've parted with pretty much my entire system. All that's left is my amplifier, but even that has a potential buyer. I'm looking to not break the bank that much but plan on spending a good 1,500 on my next amp.
I'm looking at tube amps, both stereo and monoblocks. Don't worry, I might try a different type of speaker like Magnepans, so no common ground required for SDA's.
What I've gathered is alot of these higher-rated amps use EL34's or 300B's, and still being new to the tube-world....is that good? Would I be able to roll tubes much more than other tube amps? I've been looking at amps from BAT, VTL, Cary, Wright Sound, Jolida and more. If anyone can help me out a little bit further and steer me in the right direction it'd really help a bunch. Trying to get 'my money's worth' I guess you can say, but aren't we all? I want to get a tube amp that'll give me the option to cycle through a variety of power hungry speakers. Nothing like 1.2's or 2.3's but you catch my drift.
If anyone out here has an amp that might suite my needs, toss me a PM. Would like to get a good deal on something if possible, let me know what you have. Otherwise I'll keep my eye out on the gon for any recommendations posted here.
-Freddy
Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk SR104
heiney9 wrote: »
Any clue how to use the internet? Found it in about 10 sec.
Post edited by kawizx9r on
  • kawizx9r
    edited October 2009
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Ricardo
    Ricardo Posts: 10,636
    edited October 2009
    300B's will only give you a few watts (like 5 WPC) and should be used with very high efficiency speakers (like horns). Not a very versatile amp.
    The EL34 family will give you more power (like 40WPC and up) and can be used with a wider variety of speakers.
    SOPA
  • george daniel
    george daniel Posts: 12,096
    edited October 2009
    Like Ricardo says,, if you are driving a very efficient speaker,,then either one of those amps would fit the bill,, if it were me,I would go with the Wright,only because I'm more familar with the company and George's(RIP) build quality,PTP and such.Good luck
  • kawizx9r
    edited October 2009
    Sounds good.
    I'd grab that Wright now but I still got another check going to the CA. address and by the time I'm there with my check this thing will probably be gone. I just wanted to make sure I'd be able to run non-efficient speakers...something in the 85-88 range. Would hate to think I bought a nice amp just to have to buy another.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Ricardo
    edited October 2009
    Not sure yo got it....The Wright will drive low efficiency speakers, but at only 8 WPC, don't expect too much out of it. You need a different type of tube i(like the EL-34)if you want to drive low eff speakers at decent levels.
    SOPA
  • george daniel
    edited October 2009
    kawizx9r wrote: »
    Sounds good.
    I don't think that you will be happy with those Wrights UNLESS you are gonna drive a Single Driver Speaker,(Hornshoppe,ete),or a very efficient pair of say Horns,(Klipschorn),etc.You get the idea.Good luck
  • organ
    organ Posts: 4,969
    edited October 2009
    You didn't mention what speakers you're using.
    The 300B is my favorite output tube but they need very efficient spakers. If you have any Polk RT speakers, they will sound fantastic. But to get the most out of them, you should use very efficient speakers. Mine sounded best with a pair of Klipsch La Scala.
  • kawizx9r
    edited October 2009
    organ wrote: »
    I didn't mention any speakers I'm using because I don't own any speakers anymore (check the recent F/S threads posted by me).
    I did mention though that I would like to drive anything like a pair of Magnepans, which I've been wanting to try out now so if that gives you an idea....yes Maggies that I don't own just yet.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • thsmith
    thsmith Posts: 6,082
    edited October 2009
    kawizx9r wrote: »
    Maggies are in efficient speakers and will need closer to 100wpc to drive in a fair sized room. At least that is a friend of mine experience. He has 1.6s I think and is using Manley Snappers.
    You really need to decide on the speaker to match AMP or visa versa.
  • madmax
    madmax Posts: 12,434
    edited October 2009
    The 300B, 2A3, 45 and other "triode" tubes are only a few watts. Did anyone mention you need horns or something of a similar efficiency speaker with any of the above.
    As a rough estimate here are the typical wattages, usually in a push pull style amp, usually 4 big tubes:
    EL34 40wpc, speaker efficiency 92 or higher
    EL84 16wpc, 93 or higher
    6550, KT-88 60wpc, 90 or higher
    300B, 8wpc, 96 or higher
    2A3, 3wpc, 98 or higher
    (these are baselines only and there are a lot of other power tubes out there).
    When you see a lot more big tubes you may be between 100 to 200wpc. 87 or higher eff.
    All of them sound good. :)
    madmax
    Vinyl, the final frontier...
  • beardog03
    beardog03 Posts: 5,550
    edited October 2009
    There is a very good deal on a Cary V12 on the `Gon
    http://www.audiogon.com/cgi-bin/cls.pl?ampstube&1259622599&/Cary-Audio-Design-V12-cad-280s
    No affil.......just ran across the ad this morning
    I may still have to part with mine also....tryin not to though
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • george daniel
    edited October 2009
    madmax wrote: »
    madmax
    Very good information Max,, thanks,, using my rig as an example,,SDA1C==90 db efficiency,, I'm running a Quicksilver GLA with EL-34 output tubes,, with the 60 watt trannies,,the amp is spec'd at 40 watts/channel,, so I'm boderline,, I did get my ears on some Hornshoppe single driver speaks that were powered by a 1.5 watt SET amp,, I cannot remember their efficiency rating, but it's gotta be up in the high 90's.
  • kawizx9r
    edited October 2009
    Geez, so I should just stick with what I have then. Well regardless I'm book marking this site because there's a ton of great info.
    Ok some of you guys might kick me in the nuts, but things will work out here between the wife and I. Seeking counseling and, well we don't know why we didn't do it before.
    Anyone have a pair of Maggies for sale near me? :D
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • organ
    organ Posts: 4,969
    edited October 2009
    DON'T get the triode tubes for Maggies.
    Why not a tube pre and SS amp?
  • george daniel
    edited October 2009
    Would his Moscode 300 be able to drive them?
  • madmax
    edited October 2009
    kawizx9r wrote: »
    Just a FYI to point you in the right direction. Bigger speakers can be more efficient than small ones. For example the 1.2's are around 92 db eff. Many much smaller speakers are 87 to 90 db efficient. Lets say you pick out one that is 89. To get the same volume level it will take twice as much amplifier power to drive the 89 than the 92.
    I know when you look at all those drivers in the 1.2's you are assuming a hard load. Not true at all.
    madmax
  • beardog03
    edited October 2009
    is it the same between 4 and 8 ohms also ?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • kawizx9r
    edited October 2009
    I've heard a bone-stock (even had the original power cord) 300 run a pair of maggies and it sounded NICE. I would like to do the same since I'm planning on sticking with 2 channel.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
