HID 9007 Replacement Headlights
Systems
Systems Posts: 14,872
edited October 2009 in Garage Sale
I have a set of BNIB HID headlights for anybody using dual beam 9007 headlights. Plug and play set-up. No extra runs of wiring needed. Uses the power from the OEM wiring harness. Simply plug into the HID harness from your OEM headlight leads, mount the balast and plug into the new HID bulbs you install in the factory location. $150 shipped.
Testing
Testing
Testing
