Anyone ever upgrade a pair of RT2000's?
dpowell
dpowell Posts: 3,081
edited October 2009 in DIY, Mods & Tweaks
A pair of RT2000's (in fact, my originally owned and previously sold pair) fell back into my lap yesterday. I like their sound but they do lack in the mid range department where their older siblings (RT3000's) deliver. I contribute this to the fact that the 3000's have the additional 6.5" midrange driver and Polk does some tricky x-over stuff with that configuration.
I got to looking at my RT800's which I recently purchased and realized that I essentially have the 1 tweeter, 2 mid-range driver configuration there.
What I'm wondering is whether or not I can DIY an upgrade to the RT2000's and essentially replace the 1 tweeter, 1 mid-driver upper section with the 1 tweeter, 2 mid-driver part from the RT800's and acheive a better sound.
Thoughts?
Post edited by dpowell on
  • ViperZ
    ViperZ Posts: 2,046
    edited October 2009
    dpowell wrote: »
    Thoughts?
    Are cabinet dimensions the same? You will obviously need different crossovers... Maybe try RT800 crossovers, but then you will have to figure out how to hook up the subwoofers - hook them up via separate LFE and make them completely separate from the upper section might be the easiest way.
    I haven't seen the RT800 crossover, but you will have to figure out how to hook up 2 mid drivers instead of 1. Hooking them up in series will give you higher impedance (if I remember, they are 4 Ohm drivers, so you will have 8 Ohms)... if you hook them up in parallel, you'll get 2 Ohms... Something to think about.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
