Carver CT28v preamp hum issue
michaeljhsda2
michaeljhsda2 Posts: 2,201
edited October 2009 in 2 Channel Audio
When I connect my CD player directly to the Carver TFM 35 amp there is no hum whatsoever, even at full gain (the CD player is powered on but it is not playing) When I put the Carver CT 28v preamp into the chain, hum is heard from the speakers from ¾ to full gain on the amp. My conclusion is that there is definitely a ground loop issue with the preamp. I repeated the same process with a Carver CT 27v preamp and it also hums as well. Would the above device eliminate the hum or should I replace the preamp with another brand that has balanced outputs? Does this device work?
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=3952333&SRCCODE=CNETFEED&cm_mmc_o=2mHCjC2WHaCjCVqHCjCdwwp
http://www.radioshack.com/pwr/product-reviews/Car/Accessories/Car-A-V-accessories/RadioShack/p/2062214-Ground-Loop-Isolator.html
SDA SRS 2.3TL's
SDA 2B TL's
  • fbm211
    fbm211 Posts: 1,488
    edited October 2009
    I had a problem like that and ran a grounding wire from the Cd transport chassis to the preamp ground lug and hum gone...
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • michaeljhsda2
    edited October 2009
    I connected other CD players to the preamp and it still hums. BTW there is nothing else connected to the preamp except the CD player (no cable tv, subwoofer connection,etc). In fact, without any CD player hooked up...it hums.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Systems
    Systems Posts: 14,872
    edited October 2009
    A gound loop would cause hum regardless of gain setting.Because of the gain in the pre any noise preceeding it will be amplified especially with the pot fully open.Besides unless your amps input sensitivity is on the low side you probably will not need to set the volume pot beyond 1/2 it's rotation.
    Testing
    Testing
    Testing
  • michaeljhsda2
    edited October 2009
    GV#27 wrote: »
    A gound loop would cause hum regardless of gain setting.The design of that pre likely places the gain stage following the volume pot so any noise preceeding it will be amplified.Besides unless your amps input sensitivity is on the low side you probably will not need to set the volume pot beyond 1/2 it's rotation.
    That explains it. Thanks
    SDA SRS 2.3TL's
    SDA 2B TL's
