7.1 speaker placement help
I could use some polk advice.
I'm setting up a 7.1 system in my living room that is around 20x12. So, I only have 12 feet to play with the side speakers.
My sofa is about 7 feet long which means I will have 2-3 feet from each side of the sofa to each left/right side speaker (Rci 60) and they have to be in the ceiling about 9 feet high. The rear speakers (rci 65) will be about 5-6 feet back in the wall and probably about 4 feet above ear level.
I've been trying to figure out if the side speakers will be much of a beneft so close to the listener and in the ceiling above. If it isn't much benefit I was thinking to make it a 5.1 system and use those extra speakers for my patio.
Any advice would be greatly appreciated.
Post edited by danskir on
Go with the patio. There's hardly anything that even uses 7.1 yet & I used it for about 6 months with no particular gain in sound/enjoyment.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Yeah, good 5.1 seems to be the way to go. Set up right, it's completely engrossing sonically.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
I really like my 7.1 setup, but really the only place that it makes that much of a difference is with video games. When watching movies 5.1 is fine and if setup right better then a poorly setup 7.1. But if you play many video games then 7.1 makes a huge difference especially with shooters. You don't realize how much difference 7.1 makes until you try and pin point where someone is by sound alone, then those side speakers become very important. But for movies 7.1 has kind of been overkill so far.Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra) -
yes ull need a rear centre for rear positioning in shooting games. 6.1 or 7.1 is great for gaming.Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU -
If your system has the capability for 7.1 give it a shot. You would only have to pay for speaker wire. If you don't like it use it for the patio.
I have very few 7.1 blu-ray's but the ones that are really sound pretty awesome. I don't have the best room to put them in but I really like the effect. Most of the blu-ray's matrix the side surrounds.
Good luck.
