cheap way to interface computer USB to HK3490
rru2s
I am spoiled by the USB inputs on my living room receiver (RR2150) that allow me to directly connect the USB of my computer for audio. That way I can watch music on YouTube or sample the CD selections from Amazon and hear it on my speakers.
I need to do the same thing for my HK3490 bedroom system. It has a optical digital input and also coaxial digital input.
I am thinking this little device just might do the trick:
USB Laptop & PC Sound Card Audio Advantage Micro
It's only 30 bucks and a digital optical cable would add another 10 bucks.
I don't plan to do a lot of critical listening because I usually listen to CDs for that. However, I would think this would be better fidelity than merely using a radioshack headphone-to-RCA adapter to insert into the laptop's headphone jack.
Has anyone done this before and is the sound noticably better than the analog hookup option?
Living Room system: 52"HDTV, 4 Mon.70s, Epik Valor, Outlaw RR2150
Bedroom System: 2 Mon.60s,Velo VRP1200, HK3490
Post edited by rru2s on
A little bit more money but I'm sure it's better quality is the Hagerman USB converter.
You could build one for a bit less money if so inclined as well.Wristwatch--->Crisco -
Well, I was going to suggest the older version of the CL SoundBlaster external sound card, but, I just found it @ Amazon for $270.00!:eek:
Which is REALLY F'd up, seeing as I bought mine for $30.00 <4 years ago
I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
The extigy?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
The Soundblaster LIVE 24 bitI refuse to argue with idiots, because people can't tell the DIFFERENCE!
