Subwoofer Occasionally Fades In and Out
Mr. Mojo
Mr. Mojo Posts: 53
I've noticed that my sub works about 80%-90% of the time but I notice that occasionally it appears to be missing. I notice this on blue ray and TV broadcasts. I'm sure it's missing as I will later rewind the same part of the movie and the bass is there where it wasn't before. It's an Infinity PS210 subwoofer hooked up with a subwoofer cable I got from monoprice to an Onkyo 605.
Any suggestions for fixing other then reconnecting the subwoofer cable on both ends?
Thanks for any help. :confused:
Post edited by Mr. Mojo on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    How high is the LFE out on your receiver?
    The only thing I can think of (that used to happen to me on an older Pioneer AVR) is that there were long bass-less passages in movies. This would cause my sub to turn off automatically (10-15mins auto shutoff feature) and I'd miss some bass notes that were just too low to turn my sub back on, but not low enough for me to forget that they were there if they didn't play.
    You can also try just putting your subwoofer on an only ON feature. All mine had 3 options. An Off - Auto On/Off - ON
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Willow
    Willow Posts: 11,311
    edited October 2009
    kawizx9r wrote: »
    -Freddy
    What he said ^^^^^^^^^^^
  • kuntasensei
    kuntasensei Posts: 3,263
    edited October 2009
    Make sure the subwoofer trim on your receiver is up near 0, then adjust the gain on the subwoofer itself to bring it back to the right level. If your sub trim is down below -4 or so, you may not be keeping enough line level to the sub to keep the auto-on going.
    Also, make sure your speakers themselves aren't set to full range. The Audyssey setup on the Onkyos has an issue where any speaker that can go below 80Hz will get set to full range, in which case you're only sending LFE to your subwoofer, not redirected bass from the other channels. Set all the crossovers to 80Hz and that should keep enough bass going to your sub to keep the auto-on triggered. It will also give you more headroom on the receiver, since it's using vastly less power to drive your speakers, letting the subwoofer handle the load.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited October 2009
    I'd have to go with everyone elses suggestions. I used to have the same problem with an old Pioneer sub that I had. I had the LFE output set to low, and during long passages without bass, the subs auto-off circuitry would activate. It would usually stay off until the next reasonably strong bass passage...quieter bass passages wouldn't suffice to turn the sub back on.
    Try turning the sub level in your AVR up, make sure the front channels aren't set to large, then adjust the gain on the sub to get it level matched.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Mr. Mojo
    Mr. Mojo Posts: 53
    edited October 2009
    Excellent suggestions.
    I'll give these a try.
    Thanks!
  • kawizx9r
    edited October 2009
    Hope it works out, although I'm almost positive what I said might be the reason your sub cuts in and out. I've experienced it, otherwise try the other suggestions IE use another cable.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • mmadden28
    mmadden28 Posts: 4,283
    edited October 2009
    Just throwing this out there--could also be frequencies canceling each other out between the speakers (if set to full range) and the sub. And some of this can be dependent on and change with room position (both the sub and the listener)
    Mr. Mojo, are you noticing these issues when you are sitting still or more when you move around a bit?
    ____________________
    Pool: Atrium 60's/45's
  • Mr. Mojo
    Mr. Mojo Posts: 53
    edited October 2009
    mmadden28 wrote: »
    When sitting.
    I have Polk RM10s set to small with 100Hz crossover. Subwoofer is set to 120Hz crossover.
    It's inconsistent. Sometimes a movie or TV plays all the way through with sub active and other times I notice the sub is missing. I rewind movie and sure enough, the sub is then active in that part of the film where it was previously missing. I notice more of a problem with TV and maybe it's because there's less low frequency bass to keep the sub active.
  • Mr. Mojo
    Mr. Mojo Posts: 53
    edited October 2009
    kawizx9r wrote: »
    I would definitely try this but my sub does not have the "on" setting - just the automatic one.
  • mmadden28
    edited October 2009
    I'm leaning towards what kawizx9r said in post #2. Perhaps check the sub output level from the Onk--up the dBs a bit. If you have to, turn the sub's own volume down if its too much bass. The signal may just be too low to keep the auto on 'on', or to turn it back on.
