Cartridge/stylus recommendations
nooshinjohn
I am looking for another cartridge for my Yamaha PX-3 turntable. Currently I am using the Yamaha mc705 low output (.3mv) that came with the table when new. I do have a Parasound Z-phono preamp, running into the tape input on my Sunfire Theater Grand V. I love the sound I am getting currently, but would like to get more depth out of my setup. I have been considering a Denon DL-160, or a Sumiko Bluepoint Special mkIII but want to consider better options at or below the $300.00 pricepoint.
Thanks for the help!
Post edited by nooshinjohn on
Audio-technica AT-OC9 MLII AT-OC9MLII phono cartridge Special Sale $339.95 - at lp gear.You could probable find this for a lower price used.
As well as this one I am considering upgrading to>>http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270451469401&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
The denon is a solid choice too as I have heard only good things about it. I just like audio technica carts myself.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Dl-160 is a great cart from what i've read/seen also the ortofon 2m series is worth a look, also AT 440mla is a good performer
Don't now if you knew this link but here ya go http://www.needledoctor.com/Online-Store/Phono-Cartridges;jsessionid=0a01054f1f4368c92f82e4a140bb965a977bd6bd162e.e3eTaxiNaN0Te34Pa38Ta38Pch90
For my Dual with ULM arm i like om10/m97xe, good sound without busting the bankMedia Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask -
I have the 160 and like it but never tried anything else excpt the Shure 97 which the Denon killed but for the price difference it should.Speakers: SDA-1C (most all the goodies)
I'll give a 2nd recommendation to the OC9MLII. I used one for quite a while on my VPI and was very pleased. It is a very detailed cartridge with fast dynamics and tight bass. Some call it bright, but I wouldn't characterize it like that. It just needs to be matched to the right system, one that is not to bright to start with. I should have kept mine because the price on them has gone up about $100 since I first bought mine. I only sold it because I was moving to a phono stage that was geared towards high output carts (PassDIY Pearl) and I didn't want to buy a set of transformers for it.
You might want to consider a better phono stage as well. The z-phono is a decent starter, but there are great gains to be had in that department. There are many nice choices in the used market. The original Monolithic and Phonomena come to mind, but there are many others.For rig details, see my profile. Nothing here anymore...
