Best aftermarket Stands - Model 10
Peabody67GTO
Peabody67GTO Posts: 25
edited October 2009 in Vintage Speakers
Hi,
I am the original owner of my 10's from 1984. I had them on a set of speaker stands and they are starting to weaken.
I know the polk stands are not available now & I saw a post on building some. I have a disiability and cannot do that so my option is to just buy a new set.
Any brand names to look for or how tall of a stand should I use. I got my old stands as a BD present and not even sure they were the correct ones.
THANKS
Post edited by Peabody67GTO on
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited October 2009
    Hi,
    THANKS
    Is there any way to reinforce them? Reglue them? etc
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Peabody67GTO
    edited October 2009
    The top part that the speaker sits on cracked so the speaker is sitting on a 8 x 4 flat surface & not 8 x 8. It is pretty sturdy but I want to make sure. I could look into maybe replacing just the top piece if I can get it off. The other stand is fine.
    I found these that look nice & built much better then mine!
    http://www.racksandstands.com/Wood-Technology-FGH-12-E-WT0208.html#ReviewHeader
    THANKS
  • StantonZ
    StantonZ Posts: 452
    edited October 2009
    I place (all) of my Monitor 10's on "tip toes" (remember those) on a carpeted floor and it really helps tighten up the bass. I tried stands way back when but didn't think they were worth the trouble (and "tip toes" are just about indestructable).
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • Peabody67GTO
    edited October 2009
    HI,
    I have hardwood floors so I need stands. What would be a good height? I can get 12" or 8" stands. I was thinking the 8" would get the tweeters close to my ear height when sitting on my couch. The 12" might be to high. I wonder what the original polks were?
    THANKS
  • Pauly
    Pauly Posts: 4,519
    edited October 2009
    HI,
    THANKS
    Use search function. There are specs on orig stands around here.
    Pauly
    Life without music would
  • McLoki
    McLoki Posts: 5,231
    edited October 2009
    The original stands also tilted the speaker back 5-6 degrees as a poor mans time alignment. (that actually worked pretty well)
