Will Onkyo 607 provide enough power?
dvran
dvran Posts: 280
edited October 2009 in Electronics
I'm the market to upgrade my receiver, and now that HDMI has set a standard for a while, I'm ready to buy.
My speakers that I've had for a while consist of the following. I'm not going to change the speakers because I love them but maybe the sub in the future.
-Fronts: RT1000P
-Center: Csi400
-Surrounds: Fxi3
I'm looking at getting the Onkyo 607. I think has some good features minus the preamp outputs, which I really don't need because I'm staying with the speakers till they or I go. I've listened to Denons and think the sound is dull. I was also thinking the Pioneer Elite VSX line because they are close in price to Onkyo, but I've heard bad things about non-ICE Elite receivers.
Any suggestions on the setup? I think the 607 will adequately power an RT line of speakers, but I wanted to make sure.
Thanks!
~Dan
Projector: Epson 705HD on 106" DaLite
TV: Samsung 50" Plasma PN50B550
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
Sub: Velodyne Minivee 10
PS3 and Xbox
Post edited by dvran on
  • Kex
    Kex Posts: 5,260
    edited October 2009
    Dvran, the short answer is that the 607 should do well enough with those speakers, and you really shouldn't be risking any damage unless you turn it up beyond reference level. This will depend on how you calibrate it initially, but often this means keeping the receiver about twenty clicks (usually expressed in a "dB" measurement of some sort) away from whatever its maximum setting is. Use a common sense approach regarding playing loud for too long and you should be fine. Otherwise, use an SPL meter to make sure you're not trying to get it play beyond 85dB(A) except for occasional loud passages (explosions, etc.).
    Some might suggest the Onkyo would be an excellent match with the bigger RT series speakers from that generation, since they are fairly laid back IMO, rather than detailed, but the Onkyo is reputed to be on the bright side, so it might make them a little less muddy, if you prefer a more forward sound.
    That said, however, when I first played around with those speakers, I found that I got much better results from a NAD receiver alone (the slightly older models, without HDMI, are attractively priced currently, new and refurbished) than with an Emotiva external amplifier, despite the difference in power ratings. Their bass output (thump and precision) can be really quite wonderful, for music especially, and they really seem to pair with some systems better than others. I have not heard them myself with an Onkyo, so I cannot give a direct comparison, and your tastes may well be different in any case. There are a few examples here of Polkies that added an amplifier to an Onkyo/RTi based system and were very happy with the improvement.
    This is probably not your priority, from what I understand of your post, but for two channel listening, without the center and surrounds, I would highly recommend one of the little JoLida hybrid integtrated (tube pre & solid state amplifier section) units with those big RT1000. Even the 30w/ch of the 1301 can really waken those big RT speakers up, with surprising results.
    Otherwise, despite having a powered tower, you should really still consider adding a subwoofer, if you can. Entry level models that will work for special effects in movies start at about $150 (but not so much for music, unless you just want thump and boom), and you can get a bit more performance at that price if you buy used. Otherwise, it really helps if you can push your subwoofer budget above $500 IMO.
    Conclusion? Yes, it is more than likely that you can use an Onkyo 607 with good results. Yes, you may get significantly better results with other receivers that are better at waking up the bass potential of the bigger RT line speakers (and this does not depend on printed power ratings IMO). Yes, adding an external amplifier to an Onkyo has yielded significant improvement according to some Polkies. Yes, you should plan for a subwoofer. No, you do not need any of this!
    Good luck!
    Alea jacta est!
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2009
    I don't think it will sound bad, but I would look for an AVR which has Pre amp outputs. You could always use an AVR with Pre amp outputs in the future, if you do it now you could save some cash later.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    disneyjoe7 wrote: »
    +1
    I have RT1000P's as well and was pretty set on keeping them until they croaked. Things changed and I needed a receiver with preamp outputs, something my older receiver didn't have and you can't imagine how much I was kicking myself cause of that. Well, I've still got those RT1KP's but they're on surround duty now with SDA 1C's up front. You never know when you'll find something you might want or something you can upgrade with. Having preamp outs now really gives me peace of mind.
    Question, have you heard your CS400 powered by an external amp? That thing is a beast of a center channel and you owe it to yourself to hear one powered properly. :)
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • dvran
    dvran Posts: 280
    edited October 2009
    I do have a subwoofer. Sorry if I stated that wrong in the post. It's a Velodyne and does a great job. I got my Polk speaker about 10 years ago when Circuit City would have blowout sales. RIP CC. I picked up the 1000Ps for $250/pair.
    I do not run the built-in subwoofer with the RT1000Ps in movie mode, its just a wash. In 2-channel listening though I turn them on, its almost perfect bass for rock and jazz.
    Thanks,
    ~Dan
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    PS3 and Xbox
  • dvran
    dvran Posts: 280
    edited October 2009
    kawizx9r wrote: »
    I've never heard the CS400i with an external amp, should be interesting though.
    I'll look on the Onkyo outlet and see if they have any last year models of the 806 which I believe has pre-outs.
    ~Dan
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    PS3 and Xbox
  • kawizx9r
    edited October 2009
    dvran wrote: »
    806 does, but some prefer the 805 model. Easy search on Polk forum will list a few threads describing the main differences between the 2. But either one of those should be sure to please.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • dvran
    dvran Posts: 280
    edited October 2009
    kawizx9r wrote: »
    Refurb has the 806 for 599, not too shabby for a refurbish with warranty:
    http://www.shoponkyo.com/detail.cfm?productid=TX-SR806&modelid=77&group_id=1&detail=1&ext_war=1
    ~Dan
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    PS3 and Xbox
  • kawizx9r
    edited October 2009
    dvran wrote: »
    I do have a question, what Denon did you listen to that gave you a 'dull sound'. For home theater, if I couldn't get a Pio elite I'd be going with a Denon. I love the warm sound they produce which is especially a plus when it comes to HT. It's also playing its part as a pre in my 2 channel listening, which will change later of course but it continues to satisfy in that area as well.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • dvran
    dvran Posts: 280
    edited October 2009
    kawizx9r wrote: »
    Not exactly sure. They were brand new lower end models $500-1000. The Harmon Kardon I though sounded the warmest but I've heard bad things about their quality.
    ~Dan
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    PS3 and Xbox
  • Kex
    Kex Posts: 5,260
    edited October 2009
    dvran wrote: »
    ... The Harmon Kardon I though sounded the warmest but I've heard bad things about their quality.
    Dvran, if you liked the sound of the harman/kardon when you heard it in a store, then conventional wisdom would have it that you will like the sound of an Onkyo less.
    I still own both Denon and h/k, and prefer the h/k (even though it was a vastly lower priced model, with half the stated power output). I prefer NAD compared to both of these (by quite a bit, for sound quality, with fewer bells and whistles). As for as "bad things about their quality", I'm not sure I would agree entirely, despite the long threads on the topic on some forums. I had no problems with mine, ever, and other Polkies use them with no issues either. No receiver is exempt from issues in any case, which includes Onkyo, and perhaps especially where HDMI issues are concerned. The AVR-254 is a great bargain IMO, from amazon.com (pricing fluctuates above and below $400), but you can also purchase refurbished models with warranty from their official eBay store if you want to save some extra (reports I have read seem to suggest you may get lucky, or you may get a unit with minor blemishes that are visible).
    http://www.amazon.com/Harman-Kardon-7-1-Channel-Receiver-Repeater/dp/B0016BGRX6/ref=sr_1_2?ie=UTF8&s=electronics&qid=1254864198&sr=8-2
    http://stores.shop.ebay.com/Harman-Audio_Harman-Kardon_W0QQ_fsubZ2QQ_sidZ26519532QQ_trksidZp4634Q2ec0Q2em322
    Alea jacta est!
  • buymesome
    buymesome Posts: 281
    edited October 2009
    Here is what I think
    Buy an onkyo 607 because it has plenty of power and it should be used for movies only because thats its job . People say add an external amp but I say whats the point if a decent amp will cost alot of money especially if your needing more than 3 channels . You can buy an onkyo 607 for $400 brand new that has dolby LLZ for when studios start encoding it
    With money left over you can buy a realy nice 2 channel amp and preamp that will destroy any avr when it comes to playing music costing alot less than what most folks pay for thier super priced avr and external amp
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    buymesome wrote: »
    The point of adding an external amp is to get the most out of the speakers that you paid good money for....
    Amps aren't just for 2 channel listening.
  • buymesome
    edited October 2009
    For HT is not as important to have great musical speakers that cost alot as the sub makes up for the big bass . For musical reproduction and higher fidelity you should have 2 separate speakers preamp and amp
    HT doesnt differ that much with good or great speakers as 2 channel music listening does
    If you realy do have amazing speakers then why buy an avr in the first place ? Wouldnt you then just go buy a separate processor and amp Otherwise your just being limited by the processor inside the budget avr
  • kawizx9r
    edited October 2009
    buymesome wrote: »
    In all my experiences (and I bet many others can vouch as well) HT listening benefits greatly from external amplification just as much as music. Music's alterations though provided from IC's/speaker wire/etc. can probably be heard easier especially when you've listened to the damn song +1000 times and know every beat to it.
    As for buying an AVR, there are many decent receivers out there that'll work as a good pre/pro. Buying a separate processor though can come at a higher cost, then you'll definitely need to add an external amplifier. I can go on and on, but an AVR is convenience.
    Why do people buy Xbox 360's/consoles when a PC can blow every console out of the water?
    Back to the subject though, unless you're really into HT then by all means invest your money there. But the first thing that comes to mind when I hear the word audio is music, not HT. And those that do have HT come to mind first, are probably using that setup for 2 channel listening. Are you going to tell them to buy a tubed preamp/amplifier? Or purchase another set of 'musical' speakers?
    One last thing too, external amplification doesn't just give you "more bass" it lets your speakers give you better sound quality. Even at lower volumes the difference is there. It's one thing to not believe in cables/speaker wire/etc but it's another to not believe in external amplification.....even if it is just for HT.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited October 2009
    buymesome wrote: »
    There are huge benefits to be had with external amps in HT setups...even if you're using an AVR as a pre-pro. Some of the AVR's on the market have everything plus more that some of the pre-pro's have. To really get a nice pre-pro, you've gotta spend a lot.
    Amps can make a huge difference though in highly dynamic scenes...explosions etc...A more powerful amp is going to be able to reproduce these huge sound effects a lot more accurately, smoothly, and without as much strain on the speakers.
    It's a whole lot more than just "having more bass".
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • kawizx9r
    edited October 2009
    ^^^^+1
    Great minds think alike Curt :)
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited October 2009
    I am with Curt and Freddy on this one. Amps will make a diff. in HT as well, and you don't know what you are missing until you try it. The 607 is a quality unit, but for about the same price, maybe a little more you can get an 805/806 and be done with it. Both the 805/806 have pre-outs and do everything that the 607 does. The "new" Dolby Digital PLIIz IMHO is not that big of a deal. The "height" speakers are just something to clutter up your walls even more and although I have never heard this type of setup, I can't imagine it being a deal breaker for an AVR purchase. I love my 806, and have been nothing short of amazed by it's performance. They have worked out all of the HDMI "blue dot" issues with a component replacement (HDMI board I think) and it is a top notch AVR, for what it costs. The 805 does have a better amp section and Burr Brown DAC's, but the 806 is no slouch. They can still be found for good prices on the web, and IMHO you can't beat the 806 for it's price. Good luck.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • dvran
    dvran Posts: 280
    edited October 2009
    Thanks guys. I'll see what I can get the 806 for. Onkyo has them refurb for $599. I like the new 707 that's out right now but it busts the budget. The Denon 1910 gives me pre-outs so I'll check that out too. It's not a bad buy for around $550.
    Thanks for all the suggestions.
    ~Dan
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    PS3 and Xbox
  • Zeros
    Zeros Posts: 940
    edited October 2009
    You can pick up the Denon 1910 for around $400, but it does not have pre-outs. Take a look at the refurbished Onkyo 706 on shoponkyo for $480. That has preouts.
  • wutadumsn23
    edited October 2009
    HT Rig
    Blu-Ray- 80 GB PS3
  • apphd
    apphd Posts: 1,514
    edited October 2009
    I am in agreement with the majority here. While not all music is = to all other music, and not all movie soundtracks are = to other soundtracks, IMHO movie soundtracks (many of which contain music) on average tend to have more, and bigger dynamic swings than the dynamic swings in music.
    This makes me feel that better amplification is needed more so for HT than music only. But the old unwritten law of "buy as much power as you can afford" still holds true with 2 ch as well. (power being current and watts)
