Help...Need cheap sourse for Motor/ start Cap
kcoc321
Anyone know of a cheap source for Motor/ start Capacitors?
Rat shack doesn't have them...don't know others..
I need a CBB60 60uF +/- 5% 250v 25/70/21 50/ 60 hz Capacitor for my electric pressure washer.
Motor wouldn't 'start' and when I pulled the Cap, it is totally 'blown out', the bottom is literally pushed out with greyish residue around the actual cap.
Post edited by kcoc321 on
You'll probably have to go to a hvac supply house. Or you could try a Sears parts supply location. Or any shop that repairs them?I refuse to argue with idiots, because people can't tell the DIFFERENCE!
thanks SK, they didn't have one
I was just thinkin about sears...
As far as repair, its not worth much $$
I got it for $15 at Thrift store and it worked a couple of times, but they are only $120 +/- new anyway...its a 1800psi electric..great for washing car or driveway...
saves pulling out the big gas powered one....plus it is quieter -
buy a similar item then pull out the caps on that one and return it.....;)Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon -
I found one...now the only question is if sending another $25 is worth it.....
WIsh there was some way to know if the motor and pump would hold up...
A new unit runs $160 at Sam's club, so in that extent I am ahead....
just hoping I am not throwin good $$ after bad...
http://www.rjbowers.com/xcart/product.php?productid=484&cat=108&page=3
I also found a local supplier I will call tomorrow...
An another note...dang that was a great game. -
6$ plus shipping. If you can fit a bit larger, they are around 4$, don't think it should matter too much if your off on the uF rating, as long as the power max is similar.
http://www.drillspot.com/products/154411/Cge_61B2D220053NCGR_Motor_Start_Capacitor-Ignorance is strength -
