need help
jimsvm
jimsvm Posts: 307
edited October 2009 in The Clubhouse
posting pictures. anybody??
Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
Post edited by jimsvm on
  • superjunior
    superjunior Posts: 1,632
    edited October 2009
    create an account at photobucket.com and check back
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • seeclear
    seeclear Posts: 1,243
    edited October 2009
    If you start at "post new reply" or when you start a thread, there is a button below the text box that says "manage attachments". Click that and you can upload photos if you know what file you have them in on your computer, and then they will show up as thumbnails in the post. We click on them and, voila, we see your picture.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • jimsvm
    jimsvm Posts: 307
    edited October 2009
    done superj
  • superjunior
    edited October 2009
    I haven't tried it the way seeclear has suggested but that sounds much faster. from photobucket you upload your pics from whatever file you have them on your computer. once loaded, scroll over the picture and 5 windows pop up below. right click on html code and hit copy. go back to where you want to post it and paste
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • jimsvm
    jimsvm Posts: 307
    edited October 2009
    Still working on it.Called techey,maybe other problems. On anther note,looking at some RTA15tls posted on the net for 450cnd at the end of Sept.Are they worth it at 9/10 in good working order.thanks
    F1nut Posts: 50,734
    edited October 2009
    ^Your spam has been reported^
  • jimsvm
    jimsvm Posts: 307
    edited October 2009
    Little confused F1nut.Could you PM in regards to this matter.Let me no what the problem is. Thanks
  • superjunior
    edited October 2009
    get it going yet Jim?
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
    F1nut Posts: 50,734
    edited October 2009
    Last night there was a spam post in between yours and mine that has been deleted. Sorry about the confusion, I thought they would delete my post as well.
    mhardy6647 Posts: 33,964
    edited October 2009
    If your files are small enough, they can be directly uploaded and will appear as thumbnails.
    Otherwise, Photobucket or other hosting service and "" tags work fine, too.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    Another vote for photobucket! It's free and easy to use :)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
    edited October 2009
    I find Photobucket considerably more intuitive than Flikr (for what that's worth)...
