Polk CS200 and 2 R1 How do I connect
alpal301
Hi,
Im new to electronics.
I have a Polk CS200 and 2 R1 shelf speakers plus a TV with the standard yellow, red and white ports and a DVD player with the same 3 ports.
How do I connect the speakers to this TV-DVD set?
If its just a receiver between these then whats the simplest and easiest receiver out there to make the connection. I am not interested in hi end stuff just the simplest device out there to use my speakers
Thanks a lot in advance.
Yes, you will need a receiver/ amp to do this. The white and red connectors are audio, and the yellow is video. It's really easy to figure out. Just check your local craigslist and buy something cheap."They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010
