cheap spkr cable recommend
buymesome
I would like recommendations for cheap speaker cables 4 surrounds and 3 fronts
Right now I use bare wire and want to have cables with pins or bananas but my four reaers are on the wall so bananas may not work for that application
I need 25 ft each for the fronts to give me placement flexibility . Would using such great length affect sound quality ?
Does joining my speaker wire together that has been previously used affect sound quality ?
Whats the most efficient way to link two bare wires together?
Ben from the forum recommended this to me when I was looking for affordable cable.
I upgraded from bulk wire from monoprice. I am very pleased with the results, much more clarity and no noticeable harshness.
http://www.audioadvisor.com/prodinfo.asp?number=AQT4B
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Rtia9 /csia6 / FXi A6
Samsung LN46A650
SVS PB-12-NSD sub
Audio Research SP-9 MKIII (GNSC mods)
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Audio Aero Prima CD player
Pro-Ject debut -
Thats still bare cable though
Ben is the guy with all the costly components I think from reading posts. Does he use this ?
I will give brand alot of consideration thanks -
His OP says cheap.
These are good quality affordable cables.
You want cheap goto Rat Shack buy in bulk and buy locking nanners or spades and call it a day.
Good luck
PaulyLife without music would♭ -
The signal cables are 69 each that isnt too outthere although a tad over budget still may be worth it for the quality
So far from the info the audioquest has me excited as it seams to be high quality for low budget -
It starts at $69 for 6 feet. 25 feet is $141. -
I would think that Ben uses his own cable?
When I contacted him about purchasing some, he indicated that he was focusing more on producing ICs rather than speaker cable.
My guess is that he has used it at some point given his recommendation?
Dont be mad at him because he has quality **** in his rig!:D
Im glad he took to time to cut through the slew of marketing b.s. and offer a great affordable recommendation.
Most experienced folks in hi-fi shops rarely take time out to educate and not hustle a newbie.
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Samsung LN46A650
SVS PB-12-NSD sub
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Pro-Ject debut -
Canare 4S11 is a solid choice too.And at 1.19ft its one of the best bang for the buck speaker cables out there.Its also perfect for long runs.
Link> http://www.performanceaudio.com/cgi/product_view.cgi?products_id=535SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Just a piece of advice which is not audio related. The word cheap is not a good word to use to describe what your looking for. I am far from a good writer but affordable is a much better way to say what your really looking for. Cheap would be using something like old/used extension cord wire.
And if you cover it with TechFlex and heatshrink the ends you can easily build some great looking cables. :cool: http://www.audiokarma.org/forums/showthread.php?t=94203 -
+1--- Awsome link for a DIY canare 4S11 Build MLZSDA-2BTL with custom IC
Since I was using Canare StarQuad, I built my cables with 4 spades on the speaker ends so I could see what bi-wiring was all about - I did not hear any improvement in SQ, but no harm either so I have let them be. And I think the cables look really cool -
From what I've seen on many audio forums, having terminal points on the ends of cables versus bare wire does not make a difference. I prefer to have terminal only because it's easier to hookup and its a cleaner look.
Monoprice.com should have more than adequate speaker cable for you needs.~Dan
Projector: Epson 705HD on 106" DaLite
TV: Samsung 50" Plasma PN50B550
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
Sub: Velodyne Minivee 10
PS3 and Xbox -
Are you looking for spade connections or banana plugs?
Spades will most likely be hard to connect to the back of your receiver.
One question no one bothered to ask: What is your budget? -
As in extending the length? If you can just replace it. If not you will solder and shrink wrap. -
Cheap cable? Royal Cable. It can be purchased at WalMart, and is found in the car stereo section. It seems to work well enough for both car stereo and home stereo applications--it's what I'm using in my home speaker setup.
Banana plugs and such will have to be purchased separately--try Fry's Electronics or Best Buy for the twist-on type of banana plugs.
Easiest way of joining two bare wires together? Twist the wires together and cover using a screw-on electronics wire cover/cap. Again, that's what I did for the surround speakers and it seems to work well enough. -
Thats what I did, I just twisted the wire but I used paper tape for just now
My budget will be around 120
I have bananas but I will be mounting 2 on the back wall so I might need spades
I did buy some walmart speaker wire once.....never again though as there was no way to tell the polarities .When you run a long cable it becomes antagonizing -
Here is a good link on the subject of speaker wire.
http://www.roger-russell.com/wire/wire.htm
RR is over rated. Have you ever heard any of his amps?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
All the cheap speaker cable you need can be found in your own closet...har, har, har, har...but make sure you use the metal ones, not plastic.
You may have me confused with another Ben, or I may have me confused with another Ben. I can't afford expensive cables, or expensive components. What I have done is research what cables I found were real bargains. I can make Polkies IC's that sound better and are cheaper than most cables out there buck for buck, but when it comes to speaker cables the AQ Type4's are a real good deal in bulk new, or on the used market. BTW I also use the AQ CV4's which are more than twice the price of Type 4's. It all depends on your rig, and your hearing.
Ben -
Don't get hung up on numbers...What is technically wrong with Radio Shack 16AWG speaker wire?...
...Here is a good link on the subject of speaker wire.
Woger Wussell is a joke. According to guys like him all amps with the same specs would sound the same also:rolleyes:Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
There is a HUGE thread over on AVS that states just that...I think it was actually a CP member who started it. I think it got unruly so now they have the "Official All amps sound the same" thread -
Maybe a few Polkies should take up new residence over there;) They would at least have people that feel the same way:) They could pat each other on the rear and tell each other how smart they are for saving so much money on their systems. You have to love that all amps sound the same. Brings a tears to my eyes.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
At any rate, he is a well respected contributor in audio.
So was Julian Hirsch. Having tin ears doesn't seem to disqualify somebody's audio comments for some!
Again, look at the steel terminals on the back of the Mac amps and think about the impact on negating cable changes that will have. Filter all the silly Roger Russell comments through that filter!
Changing those steel posts for high quality Cardas posts does have a big impact on sonics!! I've done it and heard it! It does improve an already respectable amp. Dissimilar metal to metal contact does have an impact.
To get back to the OP questions...
If it's for audio then be sure to qualify cheap versus the intended use!I would like recommendations for cheap speaker cables 4 surrounds and 3 fronts.
Yes! That must be a huge room to need a 50 foot spread in the front! Dampening factor will be noticeably impacted by that much length! Every reduction of speaker cable length has an impact on that critical motor interface and the resulting signal back to the amplifier!I need 25 ft each for the fronts to give me placement flexibility . Would using such great length affect sound quality ?
CoolJazzA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
Personal attacks don't work. Let's keep it more positive and less hostile.
I doubt Julian cares...................since he's 6 feet under along with his tin ears"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
I believe he already is and has been"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
It's a shame so many are misled.There is a HUGE thread over on AVS that states just that...I think it was actually a CP member who started it. I think it got unruly so now they have the "Official All amps sound the same" thread
Both. Did you know he uses Cardas wiring in his own speakers? http://www.ids25.com/specifications.htmNo I havent heard his amps.
Wasn't he more into speakers when he was with MacIntosh?
Well said CJ.So was Julian Hirsch. Having tin ears doesn't seem to disqualify somebody's audio comments for some!
CoolJazz"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Well said CJ.
Agreed.
Slam dunk!
Agreed. -
I do not know that he had tin ears or not but we all will be 6 feet under one way or another someday, don't we?
In John Crossett's review of the Bryston 4 Bsst and the Audio Research SP16L and he highly recommended the combination but I beg to differ. The Sp16l is dark and bloating in the bass department while the Bryston SST line is transparent but just not there ( musical ) for me.
What I am trying to say is what's best for one's ears will not be best for others.
My friend who owns the only-left-hi-end audio in the big city, I can drop by anytime and can spend as much time if I want to listening to all his ultra hi-end demo from Krell Evo line to AR ls26 or BAT or Cary with Esoteric lines/ Rega CDPs...there is no best or perfect piece of equipments.
I am sorry if I offend any fan boy of the Bryston or the Audio Research or Krell but it's my money and my ears ( pretty golden after all these years), I buy gear that please my ears and my bank account.
I am no brand name fan boy. I use Monster speaker cables for my Pio receiver since I determine that all it can deserve. I use Kimber/ Harmonic Tech/ Audioquest since that all i derserve with my entry level hi-end gear be it Krell, Audio research or Bryston...
Peace on earth, brothers. We can piss each other off for many more moons, it will not gain or loose anything.
