RTi A5 or RTi A7
Iammancini
Iammancini Posts: 7
edited September 2011 in Speakers
Hey guys, this is my first post and i have done some searching but havent come up with the answer im looking for. I am currently thinking about adding two more sets of Polk Audio speakers to my set up. Im just starting with my surround sound, trying to replace my harman kardon stuff for polk. I currently have RTi A3's and really enjoy them, i think they sound incredible. Now i am looking into moving the A3's to my rear speakers and using RTi a5 or A7 for my fronts.
My main problem is the cost of the RTi A7, are they worth the extra money when compared to the A5. Can the RTi A7 work (temporaily without a sub) while producing deep bass. I enjoy listening to music but also like to feel the rumble of deep bass when watching movies. I have the option of selling all of my Harman Kardon speakers and putting the money towards RTiA7, but this would leave me with no sub, or i can keep the sub and get RTiA5. The sub is a 10" Harman Kardon that will eventually be replaced. Ideally i would love to get the same amount of bass from my tower speakers as you can get from a dedicated sub (my fathers old technics tower speakers for instance produced adequate bass but by using 2 12" woofers)
So long story short, do RTi A7 produce loud bass that could possibly substitute a dedicated subwoofer, or should i save the money and get RTi A5.
Just on a side note i have heard both speakers at future shop. I didnt feel like the RTi A7 were making much bass, but i also feel that the setup had something to do with this.
Thanks, Iammancini
Post edited by Iammancini on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2009
    Add more power and the lower end on the A7's will come alive but it'll never compare to a good powered sub.
  • SivaNevets
    SivaNevets Posts: 303
    edited October 2009
    the A7s are powered by cheap yamaha receivers @ futureshop, the bass sound much weaker than A5s. A7s are usually 900$ CDN a pair at futureshop and A5s were $600 a pair last week @futureshop.
    i am in almost identical situation as u. i have RTI6 as front (same as RTIa3) and thinking to move them to rear and replace front with A5/A7. The weakness of RTI6 /RTIa3 i (and some other folks in this forum) is the weak mid bass, some say this also applies to A5 so I assume its an driver issue. but again im not gonna power A7 with an extra amp (consider the cost, lots ppl are in my situation). i think i may go to A7 if they are on some really good sale. the other option im considering is simply get another PSW10 (i already own 1), to let dual sub balance the bass. i found when crossed RTI6 and CSIA4 at 60hz the bass sound more balanced than 80hz right now. I think maybe an additional PSW10 can improve the over all bass so I can cross everything at 80 or 100 hz.
    Front: Martinlogan ESL
    Center: Martinlogan Stage
    Rear: Martinlogan Motion 4
    Sub: Martinlogan Grotto-I
    Receiver: Pioneer Elite SC 1523K
    PC 2 Channel: Polk LSI7
    Headset: Grado RS2 + Grado RA1 amp
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
    Pioneer 8200BT HU
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    I "auduitioned" both and preffered the a7's over the a5's :o
    Where/when can you get the a7's for $900/pair? They just came down in price to $650ea not to long ago.... They did however have a special a week or two ago i think you got the pair + a CSiA 6 for $1100???
    The Futuresh1t that i visit has all their demo speaker's hooked up to any one of the top line receiver's they have in stock, whether it be Yamaha, HK, Denon or Pioneer....
    Usually in audio sale's you would want to have the product sound as good as it could right? I know i wouldn't buy something if it sounded like crap!
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • danz1906
    danz1906 Posts: 5,144
    edited October 2009
    WElcome to the Club!
    Go for the A5s with a sub.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • superjunior
    superjunior Posts: 1,632
    edited October 2009
    welcome to club polk!
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • Iammancini
    Iammancini Posts: 7
    edited October 2009
    maybe i would be happier with the A5's and a good sub. The sub i have now is a 10" sub but the construction is not to my standards. It is covered in plastic, maybe a sub with a nice wood box is a better option.
    Do you guys feel you get the same quality out of a dedicated sub as you do with subs in a tower speaker. To me it just seems like you can always tell that there is a dedicated sub, that is seperated from the rest of the system. Probably just a set up issue
  • packetjones
    packetjones Posts: 1,059
    edited October 2009
    I was debating purchasing the same speakers. I have decided to go with the 5's. From what everyone says the 5's have better midrange and sound great with a sub. To get good base from the 7's you will need a lot of power so an external amp may be needed. I finally decided on saving $ and getting the 5's and putting the $ that i saved into a better sub. Plus it is less likely that i will need an amp to push the 5's compared tot he 7's.
    Hope that helps.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • ultraneight
    ultraneight Posts: 1
    edited October 2009
    Check out New Egg for a good price on RTi A5 s & A7 s I just bought some today, free shipping, best price.
  • Iammancini
    Iammancini Posts: 7
    edited October 2009
    so i finally got to hear the RTi A7 properly at my futureshop along with the RTi A5. Let me start off by saying both speakers sound incredible, but after listening to some two channel audio ,i feel the RTi A7 are the better speaker (go figure the more expensive speaker is better). They do not produce deep bass, however for listening to music i would say they produce the ideal amount. The speaker sounds very full, highs mids and lows all cometogether nicely, where as the RTi A5 seemed to be missing some of the lows / mids. Keep in mind that both speakers were played with subs off, so im sure it would be even harder to decided if a sub was playing.
    So as a conclusion, i will be holding off on the RTi A5's and saving up for the A7's. Newegg has an incredible deal on them however I live in Canada and they wont ship here. I also need to figure out what duty would be on something of that value.
  • bklynNupe
    bklynNupe Posts: 728
    edited October 2009
    Welcome to the forum.
    I will say a5 and a sub without a doubt if those are your two choices.
    Do a search on this forum, you will find all lengthy discussions on the entire Rti Series.
    You can certainly learn a lot, I did.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Rtia9 /csia6 / FXi A6
    Samsung LN46A650
    SVS PB-12-NSD sub
    Audio Research SP-9 MKIII (GNSC mods)
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Audio Aero Prima CD player
    Pro-Ject debut
  • sentra02boy
    sentra02boy Posts: 1
    edited October 2009
    found the A5s for 600 for the pair on newegg.com A7s are on sale too but i went with the A5s:)
  • bklynNupe
    edited October 2009
    Congrat.
    Do you have a AVR, amp?
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Samsung LN46A650
    SVS PB-12-NSD sub
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Pro-Ject debut
  • ls7z06
    ls7z06 Posts: 95
    edited October 2009
    If you are looking for a deal.... might want to check out Polk's own ebay store where they sell refurb'd equipment. Major discounts compared to brand new. I am not trying to sell you on this.... just pointing out a budget friendly option.
  • KsKMafio
    KsKMafio Posts: 3
    edited October 2009
    guys is in Europe they cost a fortune compared to the US or Canada...I feel sick :(
    A5 1000US....
  • danz1906
    edited October 2009
    Iammancini wrote: »
    You will be happy with the A7s.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • Graboid
    Graboid Posts: 43
    edited October 2009
    I have been a happy A7 owner for about a year. I just love these speakers and enjoy listening to just about everything with them. I did get an HSU sub to grab that deep bass and they match up just perfectly.
  • domflane
    domflane Posts: 653
    edited October 2009
    I just faced the same decision, but chose the a5's for the price difference. I'm currently running cerwin vega v12f's with a polk psw 650 on an harman kardon avr354. I think the bass from the sub will be more than enough so I just went with the a5's. They should be here this week so ill let you know how they sound.
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • packetjones
    edited October 2009
    I was deciding between the same speakers. I ended up getting the 5's. The showed up the other day. I got 1 day of listening before i had to pack them back up. I am getting new carpet in the house and had to move everything into the garage while they are installing. I can not wait to get it all hooked back up and get some good listening time. I will post my impressions once i get more time to listen to them.
    From the one day i had i really liked them. The bass sounded good to me but i did not get in any movie time only music. I think you will be happy with the 5's as well.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • over50
    over50 Posts: 201
    I just bought the RtiA5 about a week ago. I can tell the difference from my M70. I was going to buy the A7 or A12 and desided on A5 with a good sub. No regrets here.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    B&K ST.3140 Power Amplifier
    HSU Research VTF2 MK3
    Vizio P65-C1
    Panasonic 605 blu ray
    Onkyo DS-A4 i-pod Dock
    Universal Remote
    BDI Icon 9429 TV Stand
  • Lietuvis91
    Lietuvis91 Posts: 909
    over50 wrote: »
    wow... old thread there, bud!
    So in what ways are the a5 better than m70s, curious to know.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • over50
    over50 Posts: 201
    More detail. More clear sound. I hear things on the A5 that i never had before, and its not old age . Also my front and surround are all same series which helps.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    Vizio P65-C1
    Universal Remote
  • gp4jesus
    gp4jesus Posts: 2,019
    ls7z06 wrote: »
    ditto. bought my RTi A7s there, January '10; $630 including shipping! recomend an external amp; 4 ohm load below 125 hz
    cheers tony
    *all connected w/Premiere ICs
