GNX12 power rating
Col_S
Col_S Posts: 16
edited March 2003 in Car Audio & Electronics
Just a quick question on the power figures for these subs. They are stated at 125watts RMS, That seems very low compared to other subs in the same sort of range. Is that 125 a realistic figure.
If you were to run 2 GNX12s off of a JL 500/1 amp rated at 500watts RMS would this be too much power for it?
Colin
Post edited by Col_S on
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited March 2003
    the gnx's are 175 not 125 -- 200 each is a realistic figure...
    the 500.1 is a bit much for them.
    if i were to use gnx's i'd be looking for a class AB that did 400 x 1 bridged into 4 ohms and get the dual 4 ohm / single 8 ohm gnx 12's.
    The Artist formerly known as PoweredByDodge
  • Col_S
    Col_S Posts: 16
    edited March 2003
    Sorry i meant 175 RMS. So the JL is to much for 2 of them. Thats not even that powerfull an amp would have though more of Polk's subs considering the next step up is the Momo range.
  • PoweredByDodge
    edited March 2003
    and now you see why for a few years i have complained that polk needs a 250 - 300 watt 10 / 12 inch sub like the db/dx were... why? because some people dont want / need a 225 dollar 500 watt sub... and most people dont want a 175 watter either... least not in my world.
    250-300 pleases the BULK of people.
  • Col_S
    Col_S Posts: 16
    edited March 2003
    Agreed!!! Most of my customers want more then the GNX but less than the Momo.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2003
    Colin
    You can NEVER have too much power. The more clean power, the better.
    Cheers,
    Russ
  • Systems
    Systems Posts: 14,873
    edited March 2003
    Cheers,
    Russ
    agreed...just turn the gain down...unless you dont have the amp...then you might want to get a smaller amp...but then again...if u ever wanna upgrade...itll give you more options
    -Cody
    Testing
    Testing
    Testing
  • PoweredByDodge
    edited March 2003
    agreed -- but its not he gain that's the issue -- well actually it is -- problem is, last time i saw a JL500.1 was a gen1 500.1 / 1000.1 and they didn't have "dialable" gains. they simply had a two position gain ... "low" or "high"... that was it. no dialable adjustment inbetween. the arguement from the rep was "the amp adjusts itself to put out 500 or 1000 watts period... so why would u want a true gain adjustment... instead, this gain simply accomidates very "off center" gains as well as your normal ****." -- if the newer 500.1 has a dialable gain, then by all means, u can just turn it back a bit and you'll be fine.
