Turntable connected via PC to reciever
Bigworm
I"ve already tried running my turntable through my reciever directly, sound quality is really poor and very quiet. I've asked around already, and what i already know is the low impedence out of the turntable does not mix properly with the high impedence inputs on my reciever. What i'm wondering is, does anyone know if i'd be able to just run my turntable to my PC's line-in then to my reciever??
I'd like to find a cheaper option then having to buy a pre-amp with phono inputs.
Post edited by Bigworm on
http://www.audioreplay.net/indexg.html
$28 delivered is as good as I've seen. Crutchfield's Recoton is $50 and PE's is $70.
Cheaper yet... go to garage sales and find an old stereo receiver with a phono input... $10? $20?
I'm in the same boat.. I have a very nice turntable.. no room for it next to the Onkyo that *has* an input... and the new HT receiver doesn't have one.
I don't know why the PC input would be any better.. it would not have the proper RIAA equalization. The link at the top talks about connecting these to a PC sound card, so I don't think you are going to escape the need for some sort of preamp. Perhaps there is a software version...? or a specific preamp intended for PCs. -
I tried running a turntable to my PC's line-in. VERY bad sound. I think it "may" have been a grounding issue. Not sure. That's about my experience with the matter. The outputs didn't seem to have enough juice either.Polk CS245i Center
Polk RT55i Mains
Polk RT25i Rears
Polk PSW-350 Sub -in storage.
Yamaha RX-V681 A/V Reciever
Sony SCD-CE595 SACD Player -
aight, thanks for the input. You saved me the trouble of having to go out and buy a set of cables to run my table down to my PC and test it for myself.
I wont even bother now
guess i'll have to suffer til i can afford a preamp, thx again -
LSi 9/C/FX
Arcam AVR-200
