Phonograph - What's with the chrome things?
michaeljhsda2
Pic is from a 1940's Magnavox console. 1st generation multiplayer?
SDA SRS 2.3TL's
SDA 2B TL's
SDA 2B TL's
Post edited by michaeljhsda2 on
Just a guess but it looks like the silver things probably are connected through a belt system and they rotate to separate the lowest record in the stack so it can be dropped independently,while still holding the rest of the stack of records up.
There's a "pusher arm" on each of the 3 larger metal pieces. They're just wide enough to push on the lowest record in the stack.
Pretty cool. The head of the tone arm is wide to allow the user to stack plenty of pennies for good tracking, too.Sal Palooza -
That's made to stack 78s :-)
I probably wouldn't recommend stacking shellac discs, though...
