SDA 2b Wiring
garyc
garyc Posts: 10
edited October 2009 in Vintage Speakers
Hello,
When I bought my SDA 2bs the outside speaker in the right cabinet was unhooked. I connected it the same as the mirror speaker in the left cabinet regarding which lead is connected white/ greeen. (Stupid or not) I have been running them like that for a month, maybe an hour or so at a time.
Recently, after about 3 hours of playing I got a medium pitch "noise" from the speakers. My son said the noise started coming and going and then stayed constant. My setup is a vintage pioneer amp with preamp out run through a vanalstine amp. I could still hear the music behind the noise, and volume still affected the music up and down, but not the constant noise. After a cool down, everything is fine, speakers amp, etc.
Did my stupid wiring decision cause this problem? The speakers were fine for several listenings, maybe I didn't listen to them for that long at one time.
Now I'm scared to use the SDA's with that amp. What should I do?
Thanks in advance for your help. Gary
  • Conradicles
    Conradicles Posts: 6,436
    edited October 2009
    Here is a link to the wiring diagram of your speakers. Check and see if the are correct. Enjoy! Welcome to the forum Gary.
    http://www.polkaudio.com/forums/showthread.php?t=55888
  • garyc
    garyc Posts: 10
    edited October 2009
    How do I tell positive from negative on the drivers. Sorry for the rookie questions!
  • Conradicles
    edited October 2009
    garyc wrote: »
    I had the same questions. Black wires are positive. There should be a painted red dot on the positive terminal of the driver. Should is the key word.;)
  • gdb
    gdb Posts: 6,012
    edited October 2009
    Do you know for certain whether or not your amp is a common ground config.? A must for SDAs.
    F1nut Posts: 52,406
    edited October 2009
    Black or blue is positive. Green or white is negative.
    You need to check that your amp is common ground as what you are descrbing would indicate to me that it's not.
  • Systems
    Systems Posts: 14,872
    edited October 2009
    garyc wrote: »
    Which Van Alstine model? What impedance are those 2B's?
    Testing
    Testing
    Testing
  • garyc
    garyc Posts: 10
    edited October 2009
    I'll look again, but the positive or neg on the drivers is the key. I have the wiring diagrahm but didn't see the difference between the pos and neg on the driver itself. I'll give it another look... thanks for the help everybody.
  • garyc
    garyc Posts: 10
    edited October 2009
    Frank at AVA said it was common ground, but maybe I was not asking the right question... I'll try him again.
