sda 2b question
superjunior
superjunior Posts: 1,632
edited October 2009 in Vintage Speakers
not too long ago I picked up a pair of 2b's from lightman. they sound excellent but at modestly loud levels the tweeters cut out. after turning the volume all the way down for a few seconds they kick in again. I figured this was probably some sort of protection circutry and contacted Russ. He confirmed it is the polyswitch that causes this? This is quite frustrating as they cut off at fairly modest levels, no where NEAR distortion or clipping. Can the polyswitch be bypassed? if so, am I risking damage elsewhere? I must admit, the kid in me likes music LOUD. am I wasting my time with these little sda's? thanks ahead
Dan
panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one
Post edited by superjunior on
  • Face
    Face Posts: 14,340
    edited October 2009
    Call Polk, they can send you replacements or you can bypass them if you're using a good amp.
  • Conradicles
    Conradicles Posts: 6,134
    edited October 2009
    Super, those are actually my old 2B's and they never once did that to me. I do not listen too loud, but I did at times really, really crank them. Like I said, never once did the poly-switch kick out.
    What amp are your pushing them with? Are you absolutely sure they are not wired out of phase?
  • superjunior
    edited October 2009
    I'm using my emo xpa-3. in 2 channal its pushing 250w to each speeker. I am using the interconnect cable, not sure what wired out of phase means? I can push my a9's to ear-bleading levels with no issues. am I just expecting too much out of these little guys? they cut out before I would even consider it being too loud
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • fbm211
    fbm211 Posts: 1,488
    edited October 2009
    Out of phase means you have the pos/neg connections mixed up.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited October 2009
    Maybe Russ rubbed his little thing on them and degraded the polyswitches.
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    God i hate polyswitches....
  • superjunior
    edited October 2009
    fbm211 wrote: »
    alright than, this is definatly not the case.
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • superjunior
    edited October 2009
    NJPOLKER wrote: »
    lol..:D
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
    F1nut Posts: 50,753
    edited October 2009
    It's entirely possible that the poly's have degraded from age and/or from being tripped too many times. It's also possible that your amp is clipping, even though you don't think it is and that the poly's are doing their job.
    Consider that for every 3dB increase in volume it takes double the power and your 2B's have rated efficiency of 90dB at one watt...
    90db - 1 watt
    93dB - 2 watts
    96dB - 4 watts
    99dB - 8 watts
    102dB - 16 watts
    105dB - 32 watts
    108dB - 64 watts
    111dB - 132 watts
    114dB - 264 watts
    117dB - 528 watts
    120dB - 1056 watts
    Do you have an SPL meter? If so, you can determine at what dB level the poly's are kicking in, which will tell you if it's bad poly's or if your amp has gassed out.
  • superjunior
    edited October 2009
    90db - 1 watt
    93dB - 2 watts
    96dB - 4 watts
    99dB - 8 watts
    102dB - 16 watts
    105dB - 32 watts
    108dB - 64 watts
    111dB - 132 watts
    114dB - 264 watts
    117dB - 528 watts
    120dB - 1056 watts
    thanks Jesse, I'll have to pick up an spl meter.
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • superjunior
    edited October 2009
    thanks for the comments and suggestions, I guess I have just one question left and any opinions are welcome. I like music loud to mind blowing LOUD AS HELL. Am I wasting my time with the 2b's?
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited October 2009
    Ha, not in my opinion. Mine get as loud as I could ever want them and still sound clean. I like them very loud at times also, and this is in a fairly large room.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
    F1nut Posts: 50,753
    edited October 2009
    I like it loud at times.....117dB is as loud as I've measured here and it's about the limit of my rig. It's very loud and will cause permanent hearing damage in short order. Therefore, I rarely listen at that level and when I do it's not for very long because I still want to be able to enjoy the music years from now. One also realizes at some point that it's not how loud the music is, it's about how good it sounds, although I have to say my rig still sounds stellar at 117dB. :D
    Anyway, what I'm trying to say is learn to appreicate the quality of the sound rather than the volume level.
    If you want rock concert levels of 120+dB, get a 2000wpc pro amp and 105dB efficient speakers. You'll be deaf in no time.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited October 2009
    NVM... dumb question
  • superjunior
    edited October 2009
    thanks again f-1. I hear what your saying. I'm not trying to blow my eardrums, I just like quality sounding music at concert levels. maybe I should start with a much bigger amp...
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • GTB
    GTB Posts: 87
    edited October 2009
    I've had my 2B's since 91....they will rock you! Something's not right.
    You are definately NOT wasting your time.
    Greg
    Polk RTi8
    Polk Monitor 40
    Polk CSi5
    Polk MicroPro 2000
    Visio 42 LCD
    Denon AVR 790
    Samsung BD 1600
    Two Channel
    Polk SDA 2B
  • hoosier21
    hoosier21 Posts: 4,413
    edited October 2009
    I would say yes. Great speakers, but not a mind blowing loud system.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    pitdogg2 Posts: 25,685
    edited October 2009
    you know I'm having the same problem with my SDA2B's I run mine with a Carver TFM45 C16pre and Sony ES x33 cd player with 10ga. speaker cable to bananas on each end. My SDA's will both trip the tweeters when my TFM meters bounce between 50 and 90 watts on the TFM45 meters. They sound great but it just drives me nuts because it just seems i can't get the sound i want from them. My Carver amp and pre amp was repaired and serviced 4 yrs ago by Roland at Carver Service I can't see why there would be anything wrong with either. My other speakers Cerwin Vega D7's will pop the fuse when the meters start bouncing past the 180 mark but that to be expected because they are rated at 200wpc.
    I want to rebuild the SDA's but my X-overs do not look like the others I've seen on the forum here.
    edited October 2009
    guess this may help My Xovers are dated july 1987 and there are two parts to it I will post pictures or send them to someone if they would like to see
    F1nut Posts: 50,753
    edited October 2009
    You need to replace the poly switches in your Polk's. Call Polk CS and they will send you new ones for free.
    That's not how it works. What's happening there is that your amp has run out of steam and is clipping.
    edited October 2009
    just a little confused? The Carver TFM45 is rated at 375 WPC how at 180 wpc is it running out of steam and clipping? When I had it serviced Roland told me my TFM45 was built just a little different than most as it rated at 425WPC. At the time he told me that this was not that unusual because some of the M series that were rated at 375wpc drove in excess of 475 wpc. Rita who works for Bob Carver and i talked and she also confirmed this, that some of the M and TFM series were over built and pushed more than what was the norm. Rita also just had some of those on Ebay recently and she stated that in her auction. I would really understand the clipping if i was bouncing the needles close and past the 375 mark on the meters. I had a pair carver 9 mono blocks(which got stolen) and the same Cerwin Vega D7's and they would still pop the Xover fuse at 200 on the meter yes i could get them to play longer with a higher than factory fuse but then i would just melt them down.
    F1nut Posts: 50,753
    edited October 2009
    There's a big difference between a bench test rating and real world use. Transients are but one example.
    Another thing, those meters aren't exactly telling you the truth.
  • inspiredsports
    inspiredsports Posts: 5,501
    edited October 2009
    I guess I'm late to the party, but wanted to share that my 2B's will sustain a clean 115 db at the center point of my 24 X 26 X 8 listening area.
    I rarely drive them beyond 95db as that is plenty loud, but it's nice to have the headroom. Make sure you periodically check the tightness of the driver screws if you consistently listen at these levels.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
