Need help identifying some speakers.
Well, I'm on my first step toward some decent home audio equipment. I have a stereo receiver, and a sub, but then ran out of money...for now. Instead of using the bose cubes I had to drive my system, I managed to pick up some free speakers that seem to be doing the job until I can save up again for actual speakers. All I know about these speakers are that they are MTX, 5-10+ years old and I believe the woofer is 10". Can you tell me what they are?
harman/kardon hk 3490
MTX AAL 1240 R.I.P.
polkaudio DSW PRO 600
MTX AAL 1240 R.I.P.
Post edited by RedBull on
Pull the grilles off and look across the top. Does it say anything?
My guess is they are MTX AAL10 speakers. Specs:
10" 3 way
10" Fiber Foam Surround 1.5" Voice coil
5" Midbass
2"x6" Horn loaded quartz
55hz - 22khz
92db sensitivity
75w rms
http://www.mtxhome.com/manuals/AALMANUAL.pdf
EnjoyMain Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I just looked. It turns out they are MTX AAL 1240's. How this ranks amongst other speakers, I have no clue. It says 200 watts.harman/kardon hk 3490
MTX AAL 1240 R.I.P.
