What amp to run RTIa9s??
Im currently building a house with a HT room. I have decided to go with the RTIa9's as my main stereo speakers however I am unsure as to what amplifier to use. I plan on doing full 7.1 surround with them, plus run some out side speakers off the same system eventually. Would something like the Yamaha Z11 be good enough? or should I go for more a Rotel power amp set up? perhaps with a denon or marantz pre amp?
Basically do the 9s really need up to 500watts?
Post edited by Poida on
IMO the more power the better. Even if you never use it I found that amps that have higher output seem to sound better at low or mid volume level.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
The Z-11 is a great AVR if you have the cash. Lowest price i have seen new: (correct me if im wrong) is about $2400. Dont know about used, but im powering my A-9's with a Pioneer Elite SC-O5 (130x7) for less then half the price. No dropoff in performance whatsoever. I currently have my Emotiva 3-channel amp doing those duties, but the SC-05 is no slouch all by itself. Would highly recommend any of the Elite: (ICE amp) models: SC-05,SC-O7, SC-25, or 27. Incredible "Bang for the buck" IMO.:D
Pat.Receiver: Pioneer Elite SC-05
Amp: Emotiva Xpa-3
Front L/R: POLK Rti-a9s':D
Center:POLK Csi-a6
Rear surround's:POLK Rti-a1s'
Sub: Klipsch Synergy sub-12
Sony Kdl-46w4100 46" LCD
PS3
Audioquest type 4 wiring. -
A Rotel 1090 amp(380x2)@8ohms would do the trick!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Agreed with Danz. I would run that whole setup using a Pio Elite SC-07/05 if you can find one as a pre/pro. As for amp Rotel 1090 or a 7chan amp with 200watts per chan. I drive my RTi12s with D-Sonic Magnum 1000S. You use power amp to drive the fronts and use AVR to driving other speakers, thats an option should you choose to go that route. Audiogon has a few things so try there also. The A9s don't need a full 500 watts but I personally like toys so I wanted to try ICEAmps so bought D-Sonic. There's a number ways to run your setup if you decide you dont want full 7 chan amp. If you really want bang for buck I would buy Outlaw Audio Monoblocks, 1 per speaker.
http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1258856342&/Sunfire---Carver-300-x-2-with-
http://www.audiogon.com/cgi-bin/cls.pl?ampsmult&1257949412&/Rotel-RMB-1095-200x5-HT-amplif
http://www.audiogon.com/cgi-bin/cls.pl?ampsmult&1258050785&/Outlaw-Audio-Model-770-7ch-200
http://www.audiogon.com/cgi-bin/cls.pl?ampsmult&1259342211&/Emotiva-XPA-3-new-in-boxShoot the jumper.....................BALLIN.............!!!!!
