I need a new remote control light switch
Ron-P
My off brand, can't even remember the name, just blew apart, so I need a new one and have no idea what to get. All I need is one light switch and one I can use with my Harmony remote. Any ideas what's out there on the cheap?
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
http://www.youtube.com/watch?v=-XUOhjW2AXM
:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D -
George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=100399015&langId=-1&catalogId=10053&ci_sku=100399015&ci_src=14110944&cm_mmc=shopping-_-googlebase-_-D27X-_-100399015&locStoreNum=1602&marketID=34
The Lutron Maestro works with Harmony IR remotes.
Here it is for $31.70 shipped:
http://www.dimmerwarehouse.com/Product_Dimmers.aspx?C=5&ID=53 -
did people record old TV commercials? where in the hell else would they get them?
Funny none the less.Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
I use the Lutron Spacer System with my Harmony and love it. I've got a "Movie" button and a "TV" button programmed. oh... and, you know... a couple of other "scenes" programmed if you get what I'm saying.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
http://www.dimmerwarehouse.com/Product_Dimmers.aspx?C=5&ID=53If...
Ron loves a film = don't even rent. -
Thanks. Had no idea HD would carry such a device. I'll have to swing by my local store and pick one up.
I've got a brand new Lutron Spacer(IR controlled)that I don't need. Actually I've got two. One was installed, the other wasn't. Let me know if you want one.Tschüss
Zach -
Lutron Spacer system if you want multiple light settings, if you just want an IR dimmer then the Maestro will work.Shoot the jumper.....................BALLIN.............!!!!!
Do I need a Lutorn System or will their light switches work solo. I only need it for one light switch, nothing more.If...
TOOLFORLIFEFAN wrote: »did people record old TV commercials? where in the hell else would they get them?
Well, the fact that the commercial was recorded onto tape during the recording process could have something to do with it...lol
Also, people getting tired of stopping the tape during commercials.
I've got hours upon hours of old Beavis and Butthead episodes from the early 90's...and they basically all have commercials in them still. Some of them are pretty funny too.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
The Maestro and Spacer dimmers will work on their own. You just have to pull the old dimmer out, and install the new one, and you are good to go. With your Harmony, you would be able to set different lighting "scenes" with the Spacer. The Maestro, as mentioned, would be on/off/adjustable-dim.Tschüss
Zach -
Thanks guys. I picked up a Lutron switch/remote combo for $40 at my local HD.If...
