Crossover replacement
cdn5003
cdn5003 Posts: 144
edited September 2009 in DIY, Mods & Tweaks
I have a pair of Boston Acoustics CR7's that have fried crossovers. The circuit board is melted the whole way through on both of them. I have no idea how the previous owner managed to do this.
I would like to replace the entire crossover. It is a two way speaker with a crossover at 2800 Hz. Will any crossover work? Can I just screw a new one in place and reconnect the wires and have it be good as new? I would like to replace this as cheap as possible. any suggestions?
I tested the woofers and tweeters and they work fine.
HT Setup: Onkyo 706; Rotel RB-1075; Rti A3; Csi A6; Fxi3's
2 CH: Squeezebox Touch; Dared SL-2000a; GoldenEar Triton 5 or Lsi9's; Parasound 2125; SVS SB12-NSD; Music Hall DAC 25.2
  • Systems
    Systems Posts: 14,872
    I'm very surprised the drivers are still functional considering how much damage the crossovers sustained. Your best bet would be to duplicate the original crossovers as the values were optimized for that specific driver pairing.Can you still read the component values on the original capacitors and resistors?
    Testing
    Testing
    Testing
