Super high efficiency pro speakers?
madmax
madmax Posts: 12,434
edited September 2009 in DIY, Mods & Tweaks
I've been getting into low power but huge sound lately. I'm wondering if I could build a pair of speakers using pro drivers and horns and get something audiophile grade? I'm seeing some 15" bass drivers listed at 101db and horns for treble at 110 db. Of course the prices vary widely too. So, given a price no object selection does anyone think this would be the way to go? Yeah, I've heard the cheap PA cabinents at $500 each. They are loud but suck. I'm thinking more about $400 JBL bass drivers and their $800 horn/driver units. Maybe something like the old Altec Lansing home speakers.
madmax
Vinyl, the final frontier...
  • Face
    Face Posts: 14,340
    Think Emerald Physics with better drivers.
  • ben62670
    ben62670 Posts: 15,969
    Check out Fostex at madisound. There are some 8" full ranges(FE206E) that are 98db efficient, fs 38hz, top out at 20k, and only cost $88. I was just looking at these last night. You can add a super tweeter, but I myself would go with a non wizzer cone like the FF225K at 96db. Look at some of the super efficient ribon tweeters, and of coarse the Fostex horns. I have never heard small horns so I have nothing to say about SQ.
    Ben
  • megasat16
    megasat16 Posts: 3,521
    Face wrote: »
    I like this one. 28" Woof-Woof!
    http://www.e-speakers.com/-strse-418/ALIAN-28A/Detail.bok
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • Midnite Mick
    Midnite Mick Posts: 1,591
    Check out Danny Ritchies' new designs over at the circle as he has been messing around with some pro drivers lately in some kits. His prices are always a very good value.
    Regards,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • Systems
    Systems Posts: 14,872
    The 8" B&C coaxials look interesting but at only 94db may not be quite sensitive enough. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=294-653
    Testing
    Testing
    Testing
  • lightman1
    lightman1 Posts: 10,801
    ben62670 wrote: »
    To be as much of a dumb **** as he is, he makes a valid statement in this post. I'm confused as to who he really is......
  • zingo
    zingo Posts: 11,258
    Look into Tyler Acoustics line of pro-driver based speakers: http://www.tyleracoustics.com/pro_dynamics.html
  • unc2701
    unc2701 Posts: 3,587
    Check out Hawthorne audio:
    http://www.positive-feedback.com/Issue31/hawthorne.htm
    http://www.hawthorneaudio.com/
    They're going to be similar to the newer Emerald Physics.
    I think you definitely want to go with an active crossover like Emerald Physics- that's the hardest part of designing speakers and it's a hell of a lot easier to tweak around with a digital crossover than it is to model, build, tweak, model, build, etc.
    Backburner:Krell KAV-300i
  • strider
    strider Posts: 2,568
    Regards,
    Mike
    The new model he's got at RMAF this year certainly did look interesting.
    Wristwatch--->Crisco
  • madmax
    Wow, it will take a little while to go through all the sources suggested here.
    Thanks!
    madmax
  • unc2701
    Where does Nikolas live? He ended up w/ my fostex back-loaded horns- they were "different" but fun. Get some ears on those if you want to hear some high efficiency single-drivers. Or find someone with Cain&Cain's.
    http://www.polkaudio.com/forums/showthread.php?t=64034
  • madmax
    Oh man, this guy makes some beautiful stuff!
    http://www.woodhorn.com/2005.htm
    mhardy6647 Posts: 35,561
    madmax wrote: »
    madmax
    yes. TAD drivers will give you the among the best sound you'll get for new production drivers.
    I am a big fan of the vintage Altec-Lancing drivers, horns and sound, though myself. Not 110 dB sensitive (well, at least not the ones I can afford), but 100 dB or better; and sweet, sweet sounding (even in a smallish room).
    Most of the JBL HF drivers/horns are a tad :-) too aggressive for my taste.
    You might want to look at this
    http://www.audiokarma.org/forums/showthread.php?t=150939&highlight=econowave
    (I guess the JBL waveguides are s'posed to be pretty good).
    and/or spend some quality time at www.lansingheritage.org and the forums therein.
