Alpine Deck Funtions
ChevyMan4x4
I bought and Alpine Deck at the pawn shop and it had a CD Text Feature.... is there any way to program a message for it to scroll or am I stuck with the defualt scroll.... Thanks
Sir Daniel X. Boom - the GNX slayer
Post edited by ChevyMan4x4 on
cd "text" is usually the name of the cd. not all cd's ahve it either.
hell i think the only cd i own that has it is ozzy osbourne - the ozzman cometh.
so when i put it in, the alpine scrolls "the ozzman cometh".
i do not believe there is a way to program it.The Artist formerly known as PoweredByDodge -
well I have CD text on my deck. The way you program the text is when you put a CD in there.. you can actually name each CD. I have a pioneer CD Recordable Deck that lets me put text before finalize so its pretty nice. But back to the message. You cannot program the deck to have its own message but on each CD that you put in there. Depending on the model you can press the display key and hold it down while playing a CD without text and you can program the text using the buttons that lets you scan letters and the other buttons as the space button. Or better yet.. read the manual or if you dont. go to their site and download the manual.Equipment List:
Head Unit: Kenwood Excelon XXV-005
Planet Audio P13.3
Ipod 60 GB
XBox
AMPS:
Kicker KX1200.1
Kicker KX850.4
Speakers:
Front: Kicker RS65
Rear: Kicker RS65
Rear Deck: Pioneer 4x10 (AAARGH)
Subs: 2 Kicker 15L7
my car: http://www.cardomain.com/ride/571313 -
Hey ChevyMan,
Did you check Alpine online, most companys these days have their manuals, even the old ones online.
StuffYour system is only as good as your weakest component...!
OnkyoTX-DS 797
NAD C270/ Mains
Mains: LSI9's
Center: Cs400i /Biwired
Rear: Fx300i
Rear Center:CS 245i
Dvd: Onkyo DVS 555
Vision RCA 36" Premiere Series
Bang & Olfsen RX Turntable
Psw 350 Front/Psw 202 rear
Kimber Cable 4TC Mains HF
Monster Originals/Center
Kimber Interconnects
Monster XP Everywhere else
PS2/Gamecube
