Monitor 40s or TSI 300?
MANSKITO
MANSKITO Posts: 295
edited September 2009 in Speakers
I recently came into some money (won a raffle! :D) and was thinking about stepping up my current 2 channel system to a 5.1. Right now I have a pair of Monitor 40s and psw 10 sub that are powered by a Yamaha 463 AVR. And I'm not sure which is best, to get another pair of monitor 40s or get the TSI 300s and use the monitors as surrounds. The system will be used 60/40 for music and movies respectively and a CS10 as the center channel.
What do you guys think, is it worth the extra $50 to get the TSI 300 towers or should i stick with the monitor 40s?
Monitor 60s, CS10 front
Monitor 40s, back
PSW10:(
H/k AVR 325
Sansui Tape Deck
Pioneer PD-5010 CD player
Sennheiser HD 650s :D
Maverick Audio Tube Magic D1 DAC
AMD Phenom II 940 @ 3.8 prime stabel
4 gigs 1066, cas 5
XFX 4890 1gig
Seagate 1tb 7200.12
Creative X-fI Titanium Fatal1ty
Post edited by MANSKITO on
  • coolsax
    coolsax Posts: 1,826
    If you buy from newegg, you can get the monitor 50's for around half msrp, which is believe is the predecessor to the 300.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • dorokusai
    dorokusai Posts: 25,577
    TSi300.
