Windows 7 upgrade
polktiger
I just wanted to get some feedback on this idea...
I want to upgrade my HTPC to windows 7. I am currently running vista. For simplicity, I was thinking of getting a new HD to install windows 7 on. I didn't want to put Win7 on my vista OS drive becuase I want to keep it as a fall back. Basically if I am unable to get 7 running smoothly, I will just swap out the boot drive and resume running Vista.
Any problems with this route?
Post edited by polktiger on
Why not just set up a dual boot config on the one drive?
If you're upgrading from Vista to 7, you won't be looking back anyway -
Get Windows 7. You will not regret it. I am currently running Windows 7 RC and it is much faster than Visa. Also, it does not stop and ask you if it is OK to perform an action every time you add a program or change a setting.
There are many other reasons to get Windows 7.
Just do it!
Mikepolkaudio
Currently Own:
RTA-11T Light Oak, Aug/2011 to present
SDA-CRS+ Aug/2011 to present
RTA-11T Black, Dec/2013 to present
Previously Owned:
SDA-SRS 2.3 May/1990 to June/1991
SRS 1.2TL June/1991 to May/1995
SDA-1C Aug/2005 to Dec/2011
SRS 1.2TL Sept/2009 to Sept/2015 -
I have Win 7 running here as well, and it is what Vista should've been. I haven't run into any dirver issues yet, but that's the first thing I would check on an HTPC.
If it were me in your situation, I would get a bootable USB drive to load Win7 on and test it out that way so you can easily boot to either OS without any hassle. Dual booting is a good option as well./COLOR] [U][URL="http://www.polkaudio.com/forums/showcase/view.php?userid=68366"][COLOR="Blue"]My Rigs[/U][/COLOR][/URL] [COLOR="Red" Balanced Audio Technology | Revel | Dodd | Monarchy | PS Audio | MIT | Polk | Etc. -
Not really, assuming you want a fresh start and don't mind installing your applications again. If you want to do the latter but still keep your original Vista drive as a backup, several options there.
If you go with new HD, these might be handy but considering you're not going to swap them out consistently might be a waste of money. For someone who does it all the time, these are life savers.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817998041 -
AsSiMiLaTeD wrote: »That's called User Account Control, and it's easily turned off in both versions...
Who would run their Windows machine is full admin mode anyways? -
I've tried to install it twice, it will only allow me to install it to a small partition on my C: drive, meanwhile it will not allow me to select my almost empty
drive or completely empty E: drive. :mad:
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I've had it installed for some time now - it's great. Fast, simple, easy.
I'm launching it for my company soon - and then HP/gateway/etc will follow suit. We always seem to launch first lol.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Not me, that's for sure. -
Dual-booting would be the easiest and most convienient way to go about it. Create a small partition (50-60GB), install win 7 on that partition, and afterwards whenever you boot the machine you'll get a prompt asking you which OS you want to run.
Standard timer is 30 seconds for that prompt, but you can easily make it a 1 second prompt so it automatically chooses win 7 until you want to boot into Vista."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
Acronis True Image?
I would still back up any important documents, media, etc. before any attempted in place upgrade:
http://mossblog.allthingsd.com/files/2009/08/windows-upgrade-chart.png -
mshan242700 wrote: »Acronis True Image?]
ddrescue would be free alternative. -
I've been dual booting Win 7 RC and Vista since the RC first came out and I have to say Win 7 is great. If you try Win 7 you will most likely wind up liking it better than Vista..I did and I think it's safe to say that most people feel the same. YMMV2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III -
How is the support for all XP programs. I have a few I run under XP and I notice some of them did not run on vista.Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
Sub: Velodyne DLS-3750R
Receiver: Pioneer SC-07
Amplifier: Sunfire TGA5200
TV: Sony KDS60A2020
DBP: Sony DBP-S350
CDP: Pioneer DV-48AV
Interconnect cables: SignalCable analog II
speaker cables: SignalCable Ultra Speaker Cables Bi-wire -
If you get the "ultimate" version (or corporate) you can get XP virtualization. Otherwise, deal with it.
According to Microsoft."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
Just installed Win 7 Ultimate on a spare drive and ran the same benchmark program on both that and my Vista install. Peculiar thing... The Vista install benches faster and has vastly better video performance on video benchmarks. However, the Win 7 was 64-bit and the Vista is 32-bit. Memory footprint at boot was about the same, but the Win 7 installation boots up WAY faster.
I'll probably go ahead and roll with Win 7, but I think I'm gonna stick with the 32-bit version.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
My employer is an Action Pack subscriber, and registered Microsoft partner. We received the retail and OEM 32 bit versions of Windows 7 business and ultimate this week. I was waiting for the 64 bit versions before installing, to take full advantage of my 4 GB of memory, but after reading your post, maybe I'll install the 32 bit version this weekend. -
http://www.virtualbox.org/
I have WinXP and Ubuntu running in VirtualBox on my Win7 machine without any problems.
It's also a great tool if you want to test out a program. I use it all the time with a "virgin" OS to test software installations. -
I'm running the 64-bit win 7 RTM, and I'm having 0 issues with performance/speed compared to my previous vista install."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
i've also got 64-bit win7 running on my htpc. working great with hdmi video and sound.
i suggest you buy a solid state hard drive to install windows on. either get a ocz vertex, or a new intel (check anandtech.com for really detailed advice)
its super super super fast, silent and makes almost no heat. perfect for htpc!
then you'll also have your vista drive if things go south, but they wont.________________________________
Panasonic TH-50PZ800U; Sony BDP-S350
Sony STR-DA5400ES; Carver TFM-55
Carver TFM-35; Carver A-500x
Sony Playstation 3; Custom HTPC
Polk Monitor 10B Front; 2xPolk CS350LS Center;
Monitor 5B rears (RB0194-1 Upgrade);
Velodyne VA1012XII sub -
Just don't use it as a data storage, try to keep it as much read-only as possible. Do not use it as swap space! For static OS it is ok but they still have somewhat limited lifespan for write operations. -
Win7 is awesome. Not revolutionary, but definitely a nicer OS.
Tried the in-place upgrade on my machine for s#its and giggles... 17 hours later, it was still at 62%, so I rebooted and let it restore Vista. So the lesson here is: Clean install = an hour. In-place upgrade = Pack a couple of lunches.Equipment list:
Emotiva XPA-3 amp
