Anyone else have this issue with LSi C?
I have an unexpected issue with my LSI C I want to ask you guys about.....I have to set it about 5db louder in order to match the volume level of my LSI 9 mains. I have all three bi-wired and have checked the connections, and see nothing wrong there. And, there are no signs of anything wrong with my Anthem amp or Outlaw 990 processor. It sounds fine with the increased volume setting, but it just seems odd that it would require that much more power to achieve the same volume.
Does anyone else have this issue?
B&W 804s mains
B&W HTM4 center
Polk PSW 1000 sub
Outlaw 990 Pre Amp
Anthem MCA 30 Amp
Monitor Radius 180 surrounds
Audiosource Stereo Amp for surrounds
Denon 2910 Universal DVD/SACD Player
Comcast DVR
Pioneer Elite 42" Plasma 940 HD
Harmony Universal Remote
Blue Jeans interconnects and biwires
Itunes Air Express
B&W HTM4 center
Polk PSW 1000 sub
Outlaw 990 Pre Amp
Anthem MCA 30 Amp
Comcast DVR
Itunes Air Express
Post edited by john22614 on
Hello John. Even though I haven't done the HT thing in a very long time, I recall this being the norm rather than the issue.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
sounds about right John. I have to bump my settings a bit to get it the way I like it too.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Thanks for your replies......I know this is the norm when matching volume on speakers with different ohms, but given that the LSI's are all 4 ohm, I am surprised to see it. I believe I recall reading somewhere that the LSI center needs a lot of power, but I thought that applied equally to the 9's as well.
Oh well, I won't worry about it ......but, thanks again for your replies.B&W 804s mains
B&W HTM4 center
Polk PSW 1000 sub
Outlaw 990 Pre Amp
Anthem MCA 30 Amp
Comcast DVR
Itunes Air Express -
I have my LSIC set about 6db higher than the LSI-15 fronts, in order to hear the dialogue clearly.
Jimmy -
Mod the crossover and you won't have the raise the center's gain so much."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
The location would play big effect on LSiC...when I had CSi3 below TV, the dialog wasn't clear and after putting it on the shelf about 5ft, it made everything so much better...then upgraded to LSiC and kept the volume same as all 3 front speakersVideo: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
I had no issue with the LSiC. When I setup my system I used the AVR test tone to set all speakers at the same sound level, and the LSiC blended in fine with the LSi15s all around.
I recently replaced my LSiC with a PSB Synchyrony One Center and it made a big differance in sound quality. Amazingly, it dropped right in, and produced the same SPL as the LSiC so I did not have to readjust the settings. It opened up the center with a wider sound stage, is clearer than the LSiC, and blends in perfectly with the LSi15s. Great CC upgrade.Lumin X1 file player, Westminster Labs interconnect cable
