early 90's MM6510 2-ways questions...
epi4561
epi4561 Posts: 1
edited October 2009 in Car Audio & Electronics
Hi, I'm new to this forum. I just recently installed some of my old equipment and I have some questions. I have an early 90's pair of MM6510 2-way component speakers, (I can't remember if they came with a 2-way crossover or not. but all I have is an in-line crossover between the woofer and tweeter that cuts the lows out of the tweets.) They are powered by a PPi Art Series A404 going through an AudioControl EQX equalizer/crossover. One question is, does anyone have , or know where I can find, the specs of this speaker? Also, I'm not sure if I should have it coming out of the EQX at full range or high range. here is a photoshopped diagram of what I have.
thanks-epi
Post edited by epi4561 on
  • unrealii
    unrealii Posts: 268
    edited September 2009
    Give polk's customer service a call. Sometimes they have the specs.
    LSIm system on order =D
    Currently listening to innovation...
    Prior car systems:
    Nissan Maxima - Eclipse CD5030, Eclipse HDR109 HD Receiver, Eclipse PA5422, Eclipse PA5532, Polk SR 6500 (Front), Polk DB6510 (Rear), Image Dymanics IDQ10, active x-over setup
    Toyota MR2 - Eclipse CD5030, Eclipse HDR109 HD Receiver, Blaupunkt THA 555, Polk SR6500
  • skrol
    skrol Posts: 3,472
    edited October 2009
    Wow, I had a set of these. I might still have them in my basement. I also had the 6.5" coaxials (MM6520) and 5.25" coaxials (MM-IIIA, MM5520) . I really loved the sound of this series of speaker and used them in 3 of my cars transferring them from one to the next. I did eventually run into some problems with magnets shifting.
    The 2-way component set was MM3065 and included the MM6510 woofer, MM3000 tweeter and an outboard crossover network. Yes, I am looking at the brochure.
    Specs:
    Frequency response 35Hz - 26KHz
    Recommended power 5 - 100W /ch
    Sensitivity 90dB
    Normal Impedance 4 ohms
    The box used to have the theil small parameters on the side. I may have saved those too.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,472
    edited October 2009
    Here are the small parameters:
    fs = 58Hz
    Vas = 0.02m^3
    Qts = 0.429
    Stan
    Main 2ch:
    HT:
    Other stuff:
