RTi10's
jj38fox
Thinking about buying some Rti10's. Do these connect with a cable from speaker to amp, or bare speaker wire?
Thanks.
Thanks.
Either will work fine.
They can be connected with spades, bananas or bare wire.
Personally, I prefer bananas for the ease of connection.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I use banana plugs on my RTI10's. If your amp is really old, make sure they accept banana plugs.Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables
