Marantz, Yamaha or Denon receiver
jolax73
jolax73 Posts: 225
edited October 2009 in Electronics
Folks,
I originally posted a thread whether to get Marantz or Onkyo but it sounds like majority prefer Marantz. However, I do see that Yamaha price and features wise are not bad either for example the 765 model. What do you folks think the sound quality, video processing and HD decoder between Yamaha and Marantz. By the way, I do not care about the amp as I will be using XPA-5 as a separate amp. So I don't really care at the wattage. I am just concern to get the best bang for the buck in terms of video and audio processing. Denon not really sure but I just kind of give it as a last option here. I was hoping to get an HD radio feature too but it seems like the newer models in Yammy does not have it anymore but the older one like the 863 has it though.
Thoughts, ideas, inputs are welcomed??
Post edited by jolax73 on
  • danz1906
    danz1906 Posts: 5,144
    edited September 2009
    I stiil say Marantz!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • jolax73
    jolax73 Posts: 225
    Danz,
    You seem to be a big Marantz fan. Which model do you have?
  • POIDOG
    POIDOG Posts: 391
    FYI,
    I recently changed out my system, prior I was running a Yammi 2600, now I'm using a RX-V665. But, before you go "WTF" :eek: The 665 is used as a prepro, for a 5.1 system
    using a XPA-3 & UPA-2. HD radio to me, not a big deal as I use a SB3 for internet radio.
    The 765 would make a nice front end. The reason the 665, $362.00 brand new (not B stock) from Inventory liquidator. Works for me, the XPA drives the LSi front end and the Yammie handles movie proccessing. I will admit to being a huge Yamaha fan, as I've owned 4 different models. What fits your budget & music/movie taste is what works for you.
  • Bernal
    Bernal Posts: 991
    Denon 4308 Ci:D
  • jolax73
    jolax73 Posts: 225
    Bernal,
    I don't think that Denon falls within my budget plus I am sure you can get similar or at least better quality when you run separate XPA-5 with a decent receiver.
  • Bernal
    Bernal Posts: 991
    AVR-1610: 7.1 CH A/V Home Theater Receiver
    MSRP $379.00
    http://www.usa.denon.com/ProductDetails/4865.asp
    FEATURES
    GENERAL
    Availability May 2009
    Finish Black
    Power Output; Watts Per Channel 75
    All Channels Rated @ 0.05 THD
    All Channels Rated @ 0.08 THD
    Weight: In Pounds 20.5
    Width (inches) 17.1
    Height (inches) 5.8
    Depth (inches) 16.2
    SOUND MODES
    THX Ultra2-Certified
    Dynamic Discrete Surround Circuit – D.D.S.C - D
    Processor(s) – Bit Depth and Type 21367 x 1 32-bit Floating Point
    Dolby Pro Logic IIx – with Cinema, Music, Game Modes
    THX Post-Processing – DPL (4.0), DPL2 Cinema, DD/DTS (5.1), ES Discrete (6.1), ES Matrix, Neo:6 Cinema
    THX Ultra2 7.1 Cinema, Music and Game Modes
    THX Surround EX Decoding
    Dolby Digital Plus
    Dolby Digital Surround EX Decoding
    Dolby Digital Pro Logic II Dolby PLIIz
    dts ES Discrete 6.1 Decoding
    dts ES Matrix 6.1 Decoding
    dts Neo:6 Stereo-to-Surround Cinema and Music Modes
    dts 96/24 5.1 for DVD-Video Processing
    Dolby Headphone
    HDCD Decoder
    Audio Signal Delay (Sync. Audio with Video signal) – By source
    Pure Direct/Direct/Stereo Modes on Digital/Analog inputs
    Stereo/Direct Modes w/Pure Analog Path
    5-Channel Stereo Mode
    5-Channel Equal Power
    Video Game Mode
    Wide Screen 7.1 Mode
    Mono Movie Surround Mode
    Rock Arena Surround Mode
    Matrix Surround Mode
    Jazz Club Surround Mode
    Virtual Surround Mode – For 2 Speakers/Headphones
    Multi-Channel Stereo Mode
    DSP Effect Modes 7
    Auto Surround Mode (Analog or Digital Input Type)
    Active Center Channel In All Surround Modes
    Dynamic Discrete Surround Circuit - Digital HD
    Dolby TrueHD and Dolby Digital+
    dts-HD Master Audio
    MP3 Decoding
    WMA Decoding
    HD Radio
    XMHD
    Neural Surround Mode XMHD
    CONNECTIVITY
    True 24-bit/96-kHz Digital Input Capability
    True 24-bit/192-kHz Digital Input Capability (Denon Link & 1394)
    Assignable Digital Inputs 3
    Digital Input – DENON Link 3rd (SACD Ready)
    IEEE-1394 Digital Audio Input/Output
    Digital Inputs: Coaxial 2
    Digital Inputs: Optical 2
    Digital Outputs: Optical
    Digital to Analog REC Out
    Analog Audio Inputs, Incl. Tuner 6
    Phono Input
    Source Function Renaming
    Analog Record Outputs 2
    Front Panel A/V Inputs w/Cover * Composite and S-Video
    Video Conversion –Composite to S-Video to Component
    Video Conversion – Composite to S-Video to Composite S-Video to Composite
    Video Conversion – Analog to HDMI 480i to 480p only
    DVI/HDMI Video Inputs – Compatible with 1.1 Spec. – Multi-Channel Audio *1080p HDMI
    HDMI Video Outputs *1080p
    Composite Video Inputs 4 Incl. Front
    Composite Video Outputs 2 Incl. Monitor
    S-Video Inputs 1 for iPod dock
    S-Video Outputs
    Component Video Inputs x Bandwidth - *Assignable *2 x 60 MHz
    Component Video Outputs 1
    6-Ch. External Analog Input
    8-Ch. External Analog Input
    Banana Plug Speaker Terminals, All Channels
    Cinema EQ
    Front A/B Speaker Selector
    56 Station Auto-Preset Memory Tuning
    Radio Data System (RDS)
    XM Satellite Radio 'Connect and Play' Ready – with optional antenna
    Sirius Ready
    Rhapsody
    Direct Function (Tone Bypass)
    Volume Control Un-muting
    Selectable Muting Levels (Full/-40/-20)
    Video Select Control
    RS-232 Port – Third Party Remote Controllers
    RJ-45 Ethernet Port – Same Functionality as AVR-5805/4806
    PC Setup and Control Capability
    IR Serial Remote In/Out terminals
    +12v Trigger Output - Assignable
    Multi-Source/Multi-Zone (*Uses REC OUT)
    Pre-amp Outputs for Multi-Zone
    High Pass Filter for Multi-Zone Outputs
    Multi-Zone Pre-Amp Outputs – Selectable Output Levels
    Discrete Multi-Zone Composite Video Output - *S-Video also
    Discrete Remote Power On/Off, Source Selection and Volume for Main and Second/Third* Zones Main only
    Discrete Remote Source Selection for Zone 3
    Assignable Amplifier Configuration of Surround Back Channels
    Speaker Time-Delay and Level Controls: L/R, Sub, C, Surr. L/R, Surround Back
    Pre-Amp Outputs Sub, SBR, SBL or PLIIz
    Internet Radio
    iPod Port (Using optional AKP-100 cable)
    iPod Dock Control Port (Using optional ASD-1R Denon iDock) ASD-1R/11R/3N/3W
    USB Flash Drive Port
    Pre Labled Assignable Digital Inputs
    BNC Digital Inputs - Audio & Video
    Digital to Analog Conversion Multi Zone Outputs
    XLR Analog Input
    XLR Analog Output
    Input Delete Function
    Front Panel AV Inputs Inside Panel Composite & S-Video
    S-Video Down Conversion 2nd Zone
    Video Conversion Analog to HDMI Scaling 480p 720p 1080i 1080p
    Faroudja DCDi Video Processing and Scaling FLI2310
    Silicon Optix Realta HQV Processing and Scaling
    HDMI Video Output v1.1 Spec 1080p
    HDMI 1.3a Inputs 3
    HDMI 1.3a Outputs 1
    HDMI Audio/Video Repeater Function
    HDMI Video Switching Function
    HDMI Deep Color Support-36Bit
    HDMI xvYCC Color Space Support
    HDMI SACD Support
    Component Video Output 2nd Zone
    10-Ch External Analog Input
    Enhanced Power Amp Assignment
    Builtin WiFi Connectivity WiFi B/G certified
    Network Enabled
    USB Port with HDD Support
    HQV
    COMPONENT TECHNOLOGY
    Equal Power Amplifiers Y/5 ch
    Low Impedance Drive Capability
    High-Current/Discrete Amplifiers
    Independent Power Supplies
    Pure Audio Construction
    Toroidal Power Transformer
    Dolby Digital, dts and DSP Modes – Analog Devices, HammerHead SHARC
    Dolby Digital, dts and DSP Modes – Texas Instruments Aureus
    AL24 Processing - All Channels
    24-bit/192-kHz DACs – Burr-Brown PCM-1791
    24-bit/192-kHz DACs - Analog Devices 24-bit/192-kHz ADAU1328
    Analog-to-Digital Conversion - Bit Depth/Sampling Rate 24-bit/96-kHz
    Variable High/Low Pass Crossover Points (12/24dB) 40/60/80/100/120/150/200/250
    Built In Time Based Correction
    Advanced AL24 Processing Multi Channel
    Automatic Lip Sync
    HD Radio Tuner Built-in
    CONVENIENCE FEATURES
    Front Panel A/B Speaker Selector
    Auto Setup Calibration
    Auto/Manual Room Equalization
    Audyssey MultEqxt Room Eq. with up to eight position setup
    Audyssey MultEQ
    Audyssey Dynamic Volume
    Auto Setup Microphone Included/Type Y/Mold DM-A409
    Dual Surround Mode Spkr. Selector
    Icon-Based On-Screen Display
    Front Panel System Setup Control
    Personal Memory Plus
    System Setup/Surround Parameters Lockout
    Relay-Controlled Protection Circuits
    Microprocessor User Re-set Y/p.57
    Detachable Power Cord
    Subwoofer Peak-Level Limiter (THX)
    Pre-programmed (10 Devices) Glow Key Remote Control with Punch Through Commands
    Pre-programmed/Learning EL Remote with Backlighting and Punch Through Commands
    Audyssey MultEQ XT Room Correction with up to eight position setup
    Audyssey Mult EQ Room Correction Positions 6
    Audyssey Mult EQ Pro CalibrationCompatible/Installer Ready
    GUI Menu Support
  • jolax73
    jolax73 Posts: 225
    Bernal wrote: »
    MSRP $379.00
    FEATURES
    GENERAL
    Finish Black
    Width (inches) 17.1
    Height (inches) 5.8
    Depth (inches) 16.2
    SOUND MODES
    Dolby Digital Plus
    Dolby Headphone
    HDCD Decoder
    Video Game Mode
    DSP Effect Modes 7
    dts-HD Master Audio
    MP3 Decoding
    WMA Decoding
    HD Radio
    XMHD
    CONNECTIVITY
    Phono Input
    S-Video Outputs
    Cinema EQ
    Sirius Ready
    Rhapsody
    Internet Radio
    XLR Analog Input
    XLR Analog Output
    HDMI 1.3a Inputs 3
    HDMI 1.3a Outputs 1
    HDMI SACD Support
    Network Enabled
    HQV
    Automatic Lip Sync
    Audyssey MultEQ
    GUI Menu Support
    However I don't think this Denon has the preout........
  • apphd
    apphd Posts: 1,514
    You are correct jolax that doesn't have the pre-outs you want.
  • tboaz
    tboaz Posts: 1
    edited October 2009
    You guys seem to have a good handle on these. I am looking to replace my current receiver. I have a lower end Yamaha (HTR-6130) that I got because it fit the budget and of course I got what I paid for. There are a couple of issues with this receiver that I don't think I can live with, but I'm not sure how far up I may have to go to get what I want. The first problem I encountered was that the receiver passes thru the video from the HDMI connections, but ignores the audio. This was a minor inconvenience since I could use the SPDIF connections for the audio. The next problem was that everything that comes into the receiver in digital format "stays digital" until it is output to the speakers -- that is, there is no line-level analog output available. I have some wireless speakers for my patio that need a line-level analog signal. I might have used the headphones output for that, but of course, plugging in headphones shuts off the speakers, so I only get music outdoors or indoors, but not both. All-in-all, not a very good solution for my situation.
    Advice?
    Thanks.
  • polksda
    polksda Posts: 716
    edited October 2009
    Am doing the same search myself for use in a secondary HT setup. I plan to use the receiver with front preouts to an old Phase Linear 400 amp. Ideally, I'd like to keep the cost under $300-350.
    Many have suggested the H/K 254 refurbs available factory direct on eBay, but reading in the owners thread over at AVS, there seem to be widespread quality control issues at H/K, with the 254/354 having HDMI handshake issues, and just overall quirkiness.
    Right now I'm leaning towards a facory refurbed Marantz SR5002 ($299) or SR7001 ($485), but am having a hard time choosing.
    My HDMI devices are a PS3, HD-XA2, and Dish 211K.
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    Refurbed Onk. (706 perhaps)
    Denon/Marantz = Basically the same thing.
    Yammy = Yamaha "natural sound" - not so natural to me. Kinda thin. YMMV
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • jolax73
    jolax73 Posts: 225
    edited October 2009
    vc69 wrote: »
    VC,
    If I am using the Yammy as a pre/pro, will the thin sound affects my sonic output? Or it should not be affected? Coz I am planning to do a seperate setup: amp & AVR.
  • Hilbert
    Hilbert Posts: 316
    edited October 2009
    I agree with VC, Yam = thin.
    Have used Yam RXV 663 as pre pro for about 18 months. Recently picked up Emo USP-1 to use as a (very entry level) 2-channel pre and, whatever the strengths or weaknesses of the Emo may be, it blows the Yamaha away in 2 channel.
    My impression is some people like Yam sound but more dislike, and no other mass market manufacturer is quite so divisive.
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    jolax73 wrote: »
    VC,
    I don't have any hands-on experience with using a Yamaha as a pre/pro.
    I would imagine it will work fine. I highly recommend a reciever/pre/pro with Audyssey. Onkyo or Denon (Marantz too I believe).
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • jolax73
    jolax73 Posts: 225
    edited October 2009
    What about Pioneer? are they any better than the Yammy?
