You hear in digital, silly!
Cpyder
Cpyder Posts: 514
edited October 2009 in The Clubhouse
I thought this is a neat topic and would like to hear how many pennies (2 cents) you have to throw at it.
When a sound hits your ears, the inner working of you ear vibrates to the sound energy and neurons fire to certain centers in your brain. The firing of these neurons is a discrete signal. (It is not continuous, it can be quantified in terms of # neurons fired / second - it is digital)
Has anyone ever heard of or read any research as to what an effective sampling rate would be this signaling. I'm guessing it exceeds the highest sampling rates of digital recordings of today. But, I'm not all that knowledgeable in the nervous system and electrochemical signaling.
Post edited by Cpyder on
  • potee
    potee Posts: 610
    edited September 2009
    Man your way over my head I'v never given a thought to how it works, But I'll watch this thread as it sounds interesting.
  • madmax
    madmax Posts: 12,434
    I wonder what the effective sample rate is?
    Vinyl, the final frontier...
  • dkg999
    dkg999 Posts: 5,647
    The sampling rate of my brain is far beyond the ability of mere mortals to comprehend and lives in that quantum space within the wormhole near the omega galaxy. Long live Q.
    DKG999
  • Cpyder
    Cpyder Posts: 514
    I read somewhere that the human nervous system has anywhere from 100 trillion to 1 quadrillion synapses. If 1/10 of a percent of them where for the auditory system and 1/10 of a percent of those where firing any given second, that leaves a sampling rate of...
    (grabbing a calculator)
    100 million samples / second.
    Pretty crude math. Probably no fact in it, but still...
  • bikerboy
    bikerboy Posts: 1,211
    It all has to go through your eardrum which is analog. Just like all the stereos in the world have to go through a analog speaker. I have no idea what the sampling rate of the electrons in the auditory part of the brain would be but it must excede any audible sounds or we would have problems.
    Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
  • unc2701
    unc2701 Posts: 3,587
    There's also a discrete number of hairs in your inner ear- this is probably a bigger limiting factor than the neurons.
    Backburner:Krell KAV-300i
  • Willow
    Willow Posts: 10,997
    I wonder if having excess wax in your ear would smooth out the sound?
    nooshinjohn Posts: 25,381
    Willow wrote: »
    no... but I imagine the highs would be really bright and shiny:D There is also a possibility that scratches on LP's might be less noticeable.
    heiney9 Posts: 25,163
    Cpyder wrote: »
    Yeah, we don't hear in digital. I will say because of the complexity and sensitivity of our brains, central nervous system, interpretation, analysis, etc. There is no man made measuring device that can match or quantify or explain why we hear what we hear.
    This is EXACTLY why I always believe my ears over any printed specs or theories, or deductive scientific measurements, etc. The human brain and it's corresponding systems are far more acute than any mechanical man made measuring device or system could ever hope to be. Then add in the subjective nature of what we hear, how we hear, and our personal biases and audiophelia becomes a very personal experience.
  • madmax
    Even worse than hearing in digital, we have to multitask at the same time. I want an analog implant.
    madmax
  • Shizelbs
    Shizelbs Posts: 7,433
    Comparing it to digital is a bit of an oversimplifcation. Its a fair more complex than that.
  • seeclear
    seeclear Posts: 1,242
    +1000/\ /\ /\ /\
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • vc69
    vc69 Posts: 2,500
    Willow wrote: »
    I have some scientifically formulated earwax that makes any speaker sound like SDA SRS's. If you are interested, I will sell you a sample at a very reasonable price.
    Oh, and it also makes CD's sound analog.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • fossy
    fossy Posts: 1,378
    hope the good lord didn't use monster cables !!!!!!!!!!!
    Maybe in the ppl that are tone deaf .....:D:D:D:D
  • Cpyder
    Cpyder Posts: 514
    Shizelbs wrote: »
    True but all signals are either discrete or continuous. It is a simplification because if you wanted to, you could argue sound waves are discrete since there are a finite number of gas molecules. But then that makes you think... How "continuous" does a discrete sample have to be to be considered continuous? Can a sample rate be high enough to be considered analogue?
  • Shizelbs
    I think of digital as a binary based system where at some point there is a decoder that will take a chain of one of two inputs, and convert that into an analog equivalent. The auditory system take neural impulses (about the only thing about it that could be argued as digital), but also accounts for frequency of those impulses, physical vibration, transduced sound through the skull, and it still factors in what the other ear is presenting to the brain before its all done 'being processed'. The key difference between true digital like a CD and our system is there are thousands of input channels (if not millions), and the neuron firing rate is critical.
  • Willow
    vc69 wrote: »
    Only if it comes with a lifetime supply of belly-button lint!
  • bobman1235
    bobman1235 Posts: 10,822
    Cpyder wrote: »
    Correct, and you coudl say everything we experience is "digital" because the brain and nervous system are "electrical." But that doesn't really mean anything; if the "discreteness" is so fine as to for all intents and purposes be continuous, it's irrelevant.
    Same goes for vision; I always thought the Wagon-Wheel Effect was in fact our eyes showing their refresh rate in a funny way, it actually isn't and the way we perceive things is fascinatingly complex.
  • Willow
    if I move my fingers very fast and hear noise...That is Digital for sure!
  • vc69
    vc69 Posts: 2,500
    Willow wrote: »
    Sorry, no lint. But I can throw in some acoustically isolated toe cheese :D
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Cpyder
    Cpyder Posts: 514
    bobman1235 wrote: »
    Agreed. I almost don't want to say this because it would be for a different forum post, but could a sample rate on a CD be high enough to be considered analog like a record? I would think yes
    No, never. Analog is continuous; digital is a "plotted" representation of the continous analog signal......digital will never be continous even if you upsampled to infinity. Digital will never be *exactly* the same as the analog wave form. That's the theory, (in very simplistic terms) but how it interacts with each person's preception and interpretation of sound is anyones guess.
    Still there is a difference in sound (I perceive it) between analog and digital. Some prefer one over the other, but I doubt anyone in this hobby a long time would argue they sound exactly the same.
    You really need to read up on sampling as well because there are side effects created that have to be dealt with.
  • Cpyder
    Cpyder Posts: 514
    I mean to represent an analog signal. Not to make it sound like a record or tape.
    Also if sampling rate = infinity, then yes - you've represented every possible point and hence it is analog
    Cpyder wrote: »
    Well, I have yet to see an upsampler for audio use that samples to infinity. Also don;t forget about the side effects of upsampled signals. They need to be dealt with also.
    So again I say no, you can't upsample to high enough degree to make a digital signal sound or appear analog.
  • mmadden28
    mmadden28 Posts: 4,283
    bikerboy wrote: »
    It all has to go through your eardrum which is analog. Just like all the stereos in the world have to go through a analog speaker. ....
    Then one would expect the eardrum to convert the digital recordings we hear to analog- no? My eardrum isn't digital.
    ____________________
    Pool: Atrium 60's/45's
  • ShinAce
    ShinAce Posts: 1,194
    check out:
    http://www.lifesci.sussex.ac.uk/home/Chris_Darwin/Perception/Lecture_Notes/Hearing2/hearing2.html#RTFToC9
    He basically says the recovery time before an impulse can fire again is 1 ms = 1KHz . However, each hair has roughly 10 nerve fibers and they trigger in specific ways so they tend to trigger on multiples of frequency received.
  • George Grand
    George Grand Posts: 12,258
    I hear in color.
  • potee
    potee Posts: 610
    vc69 wrote: »
    And I always thought that was JAM. Oh well no toast with you guys
  • agfrost
    agfrost Posts: 2,426
    My ears are (eustachian) tubed.
    Tubes rule!
    Jay
    Jay
  • TECHNOKID
    TECHNOKID Posts: 4,298
    What a great topic here! This led me to do some technical experimenting. I hooked-up my scope to the output of my hear drums which reacts inversly to my "spearkers" and voila! I came to the conclusion that the signal is a sine wave thus an analog signal but I realized the brain does the pre- and the amping (yet I have to admit it is not high end but mid-fi) :cool:
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
