Building a home theater
LBrize
Just wanted to post this picture. I've been building a house for a while now, and thought I'd post this pic to the forum. This will be the lovely home theater. :0)
Post edited by LBrize on
keep us posted;)
happy buildingThe Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)
-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable -
Man Cave: 7.1
-PS Audio Power Plant Premier
-PS Audio Power backup
-Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
> Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
>Sub = MK Audio 10'
-PS3
-Onkyo 5 disc cd player
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's -
Very nice start-Enjoy!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
The only thing I suggest is make sure you read, read, read. I have a dedicated HT so feel free to ask questions, also get with forum Grimster. Make sure you run plenty of dedicated 20 amp breakers, and run ethernet cable to the room for your sources. I ran a 24 port gigabyte switch as to have plenty of bandwidth for gear as most seems to have ethernet these days. I would also run LAN cable and dedicated circuit in ceiling if you are going front PJ.
If you are planning front PJ take into considerations of dark screen wall and ceiling as to prevent light from returning back to the PJ. Those are some of the main things as of now. Other than that, if you have anything, just ask. Enjoy and check out the show case for ideas as well. Some good pics of other setups that may help you along the way.Shoot the jumper.....................BALLIN.............!!!!!
Some good advice Sherardp, obviously speaking from experience. Looks like you are off to a good start LB, she's gonna be a beaut when you are done. Keep us posted.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
I've posted this stuff before, but here's the related equipment:
PS3 for blu ray (not as impressed as the A/V media, but it's pretty good)
Toshiba HD DVD
Rotel RB 985 Mk II for 5 channels
Rotel RB 951 to round out the 6th and 7th channels
HK receiver to be used as decoder/preamp (would like to upgrade, but later)
Optoma HD 72 projector
Speakers are a mix of mid-fi, such as
Polk RT400, Polk Monitor 7, Monitor 10
Infinity RS 4,
Castle (forgot the model, but floorstanders)
BIC Venturi V604 Bipole/Dipole
Reel Acoustics 250W 12" sub
Boston Acoustics CS7
Bose AM-5
--Not sure which speakers I will put where
I wired the house with a 7.2 wall jack, banana plug jacks throughout the room
HDMI 1.3 wired through the wall with outlets as well
The wire is a decent grade 12 gauge. Bought a 250 ft roll. I hope it serves well, I have found wire to be important--good reviews on Amazon, but you know how that goes.
I have 5 rows of theater seats from a theater out of North Carolina. Unfortunately I will not be using those, but I did get a very nice couch to go in the room.
The walls were treated with sound insulation and the drywall is higher grade, thicker than the usual, but other than that, the walls are pretty standard.
The floor will be 1" oak hardwood, so I will definitely be using some room treatments. Michael Green (Roomtunes) taught me some neato tricks for acoustic treatments.
Of course, room darkening blind in the window.
That's about it, I'll post some pics upon completion. Tis a very long dream coming true!
Edit: Dedicated 20 amp breaker on the sound equipment, dedicated breaker on the projector as well, so no air conditioner, refrigerator, etc. interference. -
You will definitely want to get that screen wall darker in order to achieve maximum picture quality out of any projector. If you dont, your image will appear washed out or just very flat. Also consider Lutron dimmers for lighting, an IR kit to control all your gear if your stashing it in a closet or the rear of the room. In a dedicated HT I would highly recommend you sonsider carpet over hardwood floors. I use 1/2" sound matting under my carpet even to help out with treatment as well.
Gear list sounds good as Im sure the other guys will chime in on that dept. Not sure if you have projector mount but consider Chief RPAU which is very sturdy mount and Universal should you upgrade in future. If you need additional cabling consider monoprice or bluejeans cable. Just throwing some things out there at you as I was in your position last yr this time. Once you're in there you'll want things sounding and looking great so take all info/suggestions to heart. For popcorn machine check out Paragon as they are some of the best, I bought from Stargate Cinema. I can pass you other info as time goes on or if you have Qs. You should be excited, I spent countless hours in my HT during the build process, thinking, adding, taking away.
Edit: And dont forget your projector screen, I did not see that on your gear list.Shoot the jumper.....................BALLIN.............!!!!!
If you have any other questions, please feel free to ask!Money Talks, Mine says Goodbye Rob!!!!
looking nice ... more pictures...Are you building it yourself or a builder?Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
Sub: Velodyne DLS-3750R
Receiver: Pioneer SC-07
Amplifier: Sunfire TGA5200
TV: Sony KDS60A2020
DBP: Sony DBP-S350
CDP: Pioneer DV-48AV
Interconnect cables: SignalCable analog II
speaker cables: SignalCable Ultra Speaker Cables Bi-wire
