Adcom Pre with Tuner :)
gwh
Decided to set up a 2 channel rig.
I'll be plugging in a CD player and a Turntable.
Prefer a model that has a built in tuner and is remote capable.
Cheaper the better!
I have a Sony Minidisc Deck MDS-JE510 with quite a few blank disc if you would be interested in doing some trading. Player has a few scratches on the top and I do not have the remote.
Rock on!
G
Cheaper the better!
Rock on!
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
Where are you located?
I can get ahold of a GTP-500 i think, without remote for pretty cheap.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Okla. 73505.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
Okla. 73505.
G
Let me see if it's still available. Are you interested? If it's still available, i could get it to you for under $100 shipped.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Thanks.
Check it out let me know.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Sent the seller an email. Will keep you posted.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Yep, i can get it for you, it'll be under $100 shipped to your door. Want it?
PMing you as well.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Would like to see some pics and get a little history on the unit before I commit.....would that be possible?
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
I'll tell you what. I'm going to go pick it up anyways, and i'll put it through it's paces and see if i can't get some pics of it and such, and i'll let you know how it is and hopefully get some pics up on Monday. Deal? If it's ugly, but fully functional, and you want something in better shape, i'll cut you the same deal on my GTP-400, which is fully functional, and in GREAT cosmetic shape.
So yes.... i can get you the history and some pics before you commit. I'll pop the top off and see if it's been repaired or anything funky while i'm at it.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Do you need an amp, too?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I'm good on amplification.
Let me know about the 500 when you get time.
If you decide you want to keep it that's cool.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
:)BurpHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Sorry man, give me a day or two to find time to put it through it's paces. I have it, it looks good, just have to make sure all is well with it first. I haven't had a chance to hook it up. Just bear with me, alright? I'm sorry.
If you need something quick, i can sell you my personal GTP-400 for $100 shipped, i can get it out tomorrow after work. Pics are in the system showcase, but i don't think there's any detailed close ups. 100% functional, a 9/10 in the asthetics department. Nik will vouch for it, i believe you bought your amp from him.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
All is good. I appreciate you checking it out.
I'm waiting on some woofers I sent out to be refoamed before I can fire this rig up anyway.
I'll set tight until I hear from you.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Alright, sounds good. Should have some time tomorrow after the dr's appointment if i can lift anything well enough to rearrange the rack.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
