SDA SRS 1.2tl crossover question
vmaxer
vmaxer Posts: 5,117
edited September 2009 in Vintage Speakers
I am rebuilding the crossovers in my SDA SRS 1.2tl's...I have read several places that the mica's should be removed. Do I just remove them and forget it, or do I install a jumper??
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Post edited by vmaxer on
  • Face
    Face Posts: 14,340
    If you're replacing the original capacitors with new ones, you don't need the mica caps. Jumpers would bypass the capacitors completely and would be very bad.
  • vmaxer
    vmaxer Posts: 5,117
    Face wrote: »
    I am using all Sonicap capacitors and mills resisitors per the list below. However some posts say when this is done thet you should do away with the 750pf micas. If I remove the micas, to I leave the connection open, or jump it??
    Below is the list __________________________
    Originally Posted by Lasareath
    vmaxer,
    Call or go to Sonic Craft's website:
    http://www.soniccraft.com/ ; Call to order, 501-620-4444, you will be speaking to Elliot.
    You want Sonic Craft Generation 1 http://www.soniccraft.com/sonicaps.htm
    “Sonic Capacitors Generation 1”
    Ask for Custom Matched & as close to 1% tolerance as possible:
    Qty Rating
    (6) - 12uf (he was able to get the 1% tolerance for me)
    (2) - 0.25uf (he is going to have problems matching this and will probably get within 8% tolerance which is okay.
    (2) - 13.5uf (he could get 3% tolerance here for me)
    (2) - 27uf (2% tolerance for me on this one)
    Mills Wirewound Resistors – non-inductive http://www.soniccraft.com/mills_resistors.htm <http://www.soniccraft.com/mills_resistors.htm&gt;
    All should be rated 12 watt
    Qty Rating
    (2) - 2.7 Ώ
    (2) - 7.5 Ώ
    (2) - 11.5 Ώ (you may have to settle for 11 ohms here)
    (2) - 15 Ώ
    (2) - 22.5 Ώ (if you can only get 22 ohms that is okay)
    SDA IC upgrade and Speaker Binding Post upgrade:
    This is based on Darquknights’s upgrade. It is considered on of the best of the SDA Interconnect and Speaker binding post upgrade on the forum.
    * 15’ of what ever speaker wire you are using currently to 1.2 TLs. Hopefully something no smaller than twin lead 12 ga wire.
    * 10 Cardas CCGR short http://www.soniccraft.com/products/c...ardas_ccgr.htm
    <http://www.soniccraft.com/products/connections/bindingpost/cardas_ccgr.htm&gt;
    * Four red and 6 black delrin binding post insulators. http://www.cardas.com/content.php?ar...ing=Insulators <http://www.cardas.com/content.php?area=oem&content_id=14&pagestring=Insu lators>
    * Two heavy ¼ “ gold spades that will accept up to 6 guage wire. http://vampirewire.com/mcart/index.c...3&page=1&cat=7 <http://vampirewire.com/mcart/index.cgi?code=3&page=1&cat=7&gt;
    * All of the above except for the spades can be ordered from Elliot.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Face
    Face Posts: 14,340
    vmaxer wrote: »
    I am using all Sonicap capacitors and mills resisitors per the list below. However some posts say when this is done thet you should do away with the 750pf micas. If I remove the micas, to I leave ith connection open, or jump it??
    Open. The main capacitors and micas are paralleled, so with the micas removed, you will still have a connection.
  • vmaxer
    vmaxer Posts: 5,117
    Face wrote: »
    Thanks a lot!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
