Wall mount for my 50" plasma
Rodeo0530
Rodeo0530 Posts: 797
edited September 2009 in The Clubhouse
Hey everyone, I'm wanting to mount my 50" Panasonic plasma on the wall and I am trying to find a good mount that isn't ridiculously priced. Non-tilting mounts will work, but I think that I may buy one that allows for some tilt because I think it would provide a little better viewing angle. I've looked at a lot of different mounts, but would like to hear from some knowledgeable people on here before I make a decision. Thank you in advance!
Front - Polk Audio Monitor 70
Center - Polk Audio CS2
Rear - Polk Audio TSi 100
Sub - Klipsch rw-10d
AVR - Onkyo ht-rc180
Main Amp- Parasound HCA-2003
Surround Amp- Sonance Sonamp 260
Tuner- Parasound tdq-1600
Turntable- Pro-ject Debut III USB w/upgraded platter
IPod dock - Pure i20
TV - Panasonic Viera tc-p46g10
Sony Playstation 3(250GB)
Nintendo Wii
Power Conditioner- Panamax 5100
Not in use-
Polk Audio Monitor 60
Polk Audio PSW10
Parasound p/sp-1000
Post edited by Rodeo0530 on
  • jjwm27
    jjwm27 Posts: 123
    i got one of these for my 50 inch plasma, it seems well built and it tilts, tilt makes it much easier to connect equiptment. i like it. also i would not trust my plasma to anything to cheap.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882160081
  • bruss
    bruss Posts: 1,039
  • Toxis
    Toxis Posts: 5,116
    Sanus VMPL-50B... done. Bet you can find it on eBay cheap.
  • jimmydep
    jimmydep Posts: 1,305
    My Panasonic 50" is 3 yrs old, I used a tilting mount I got from Costco. It is very secure and easy to use, just make sure you screw into 2-wall studs and you shouldn't have any problems.
    This is similar to the one I have:
    http://www.costco.com/Browse/Product.aspx?Prodid=11380680&search=mounts&Dx=mode+matchallpartial&Mo=63&cm_re=1_en-_-Top_Left_Nav-_-Top_search&lang=en-US&Nr=P_CatalogName:BC&Sp=S&N=5000043&whse=BC&ViewAll=64&Ntk=Text_Search&Dr=P_CatalogName:BC&Ne=4000000&D=mounts&Ntt=mounts&No=8&Ntx=mode+matchallpartial&Nty=1&topnav=&s=1
    Jimmy
    billbillw Posts: 6,815
    bruss wrote: »
    monoprice.com
    I'll second that. I've been using a monoprice bracket for about 3 years. No problems. My parents have used them twice, my brother used them, (you get the idea).
    Don't pay for Sanus or other name brands. $25 is all you need to spend (plus shipping)
    http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082801&p_id=3900&seq=1&format=2
    Don't pay extra for the premium one either. The standard one is plenty strong for a 50".
    Like others have mentioned, just make sure you mount it into two studs with at least two bolts in each stud. Buy a quality stud finder if you don't have one.
    For rig details, see my profile. Nothing here anymore...
  • bruss
    bruss Posts: 1,039
    Even this one at 50 is a steal.. My friend uses this one and it is extremely solid.
    http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082806&p_id=3724&seq=1&format=2
    They are quality. I cant say enough about monoprice.
    billbillw wrote: »
  • Rodeo0530
    Thanks a lot guys. I have bought a few things from monoprice before and never even thought to look there this time. Do I really need to buy a studfinder though? I can tell just where the studs are by knocking on the wall. I guess that I would be able to find the center of the stud much easier though huh?
    Nintendo Wii
    Not in use-
    Polk Audio PSW10
    Parasound p/sp-1000
  • bruss
    bruss Posts: 1,039
    i dont think it matters how you find it. Knocking, stud finder, magic.. as long as its secure in the stud
    Rodeo0530 wrote: »
    Hmmm. $2000 TV, $10 stud finder (check Sears). I'd want to be sure I get that bolt right in the middle of that stud. Your call though.
  • kcoc321
    kcoc321 Posts: 1,788
    Rodeo0530 wrote: »
    All I will say is that "I" would not trust a wall mounting to just the knuckle test. At the VERY least I would drive some test nails to find the exact center.
    But then I am just cautious. In the last install I did for my sister, I inlaid a piece of 5/8" plywood (rest was 5/8" GWB) behind the 1/4" cabinet plywood that was the finish material. AND made an exact layout for the DOUBLE studs locations, which were installed at the exact locations for the frame.
    But that is just me.
  • Rodeo0530
    I'll go buy a stud finder even though the inner male idiot in me says that I could do it without it;) Thanks again for all of the suggestions. Haven't decided on which one as of yet because I'm attempting to find a new dishwasher right now. Once I get the dishwasher and install it, I'll mount my TV.
    kcoc321...I don't think that cautious is the correct word. I think extremely cautious is closer to correct, but that may not even be extreme enough:) If you want to go to that extent doing it, then more power to you. It sounds like you do very thorough work. You going to be around Dayton,OH anytime soon?
    Nintendo Wii
    Not in use-
    Polk Audio PSW10
    Parasound p/sp-1000
  • AGUERRA
    AGUERRA Posts: 147
    bruss wrote: »
    monoprice.com
    great prices cant go wrong
    front: rti8
    center: csi5
    surround: fxi3
    sub: eD a2-300
    receiver: onkyo 805
    ps3
  • kcoc321
    Sorry Rodeo, I am in Seattle, WA
    But post some pics and I would be glad to give some more specific advise.
  • Rodeo0530
    Thanks...I don't think that It'll be too difficult to do. I'm fairly handy with things around the house, so as long as I don't have my g/f help me then I should be fine.
    Nintendo Wii
    Not in use-
    Polk Audio PSW10
    Parasound p/sp-1000
  • swegyptian
    swegyptian Posts: 316
    IME the cheap flat mounts are fine, like on monoprice. I would steer clear of the cheapest articulating mounts though, especially if you intend on moving the TV regularly. For those I would get a better quality one, like sanus.
  • hoosier21
    hoosier21 Posts: 4,413
    if you are dtill looking, I have an extra mount I got from Parts Express
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Rodeo0530
    hoosier21 wrote: »
    I sent you a PM a while back about your wall mount, but haven't heard back from you about it. I'll be buying a mount this week probably, so let me know what kind of mount you have.
    Nintendo Wii
    Not in use-
    Polk Audio PSW10
    Parasound p/sp-1000
