System showcase update...
nooshinjohn
nooshinjohn Posts: 25,890
edited September 2009 in The Clubhouse
I have not updated my system in a while, so here it is as it exists for now;)...
http://www.polkaudio.com/forums/showcase/view.php?userid=92017
Post edited by nooshinjohn on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Looks great! The 2.3TL's do kind of fit in the room better. They aren't quite so dominating. Personally, I enjoy the look of a speaker the size of a refrigerator, but not everyone agrees...lol
    We need some nekkid pics of the 2.3TL's though!
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    I am rather embarrassed to post then nude until they are whipped into shape,(RDO-198's) as the tweeters are not the same color in each. If someone has a few SL-3000's around I would be most grateful as I want to try them stock for a while.
  • leroyjr1
    leroyjr1 Posts: 8,785
    Very nice John. I read you had to turn up the volume on the sub to compensate for the lack of bass. My 2.3tls put out some serious bass in my 26 X 16 living room. A pre amp made a big difference in the lower end. No sub needed what so ever.
  • comfortablycurt
    leroyjr1 wrote: »
    +1 You need a pre-amp. That AVR is robbing you of a lot of sound quality.
    Get something with HT bypass, and you'll still be able to use it with your HT system as well, without swapping wires around.
    I am looking for something that does HDMI 1.3 switching, but so far they are way out of my budget, but if the goodwill keeps hooking me up, I can get there in no time!;)
  • leroyjr1
    Look at the Adcom GFP-750 it has HT bypass so you'll be able to run it with your receiver. It'll made a huge difference.
    What size is your room.
  • comfortablycurt
    I meant a dedicated 2 channel pre-amp.
  • Conradicles
    Conradicles Posts: 6,334
    What if a spark flies out of the fireplace and catches the SDA's on fire?
    JK
  • NJPOLKER
    NJPOLKER Posts: 3,474
    JK
    He will call Russ to come over and put them out. And I am not joking.
  • TNRabbit
    TNRabbit Posts: 2,168
    Looks like crap.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
    TNRabbit wrote: »
    Looks like crap.
    ...thanks!:)
    why do you say that?
  • TNRabbit
    ...thanks!:)
    Just yankin' yer chain~
    Looks great. You need a pair of the BIG SRS arrays....
    Gary
    TNRabbit
    Sunfire TG-IV
  • concealer404
    concealer404 Posts: 7,440
    John, how far between the SDAs? Might not matter so much with that speaker, but they seem kindof close to me.
    But then again... i've never owned any, so i have no idea.
    They are 5'4" apart, and 6 inches from the back wall
  • leroyjr1
    How big is your room, and how far do you sit away from the speakers?
  • concealer404
    That seems close to me, but again, grain of salt, i don't know much about these. I run my speakers about 8-9 feet apart right now, and it made a HUGE difference from when they were about 5 feet apart. I was thinking about ditching them because i was unhappy with them, but now they've opened up like crazy. They just sound like big speakers and they're not. Before, they sounded like the small floorstanders they are.
    Toolfan66 Posts: 17,995
    I believe Anyone with the SDA's should do seperates if you want them to shine!!
    The AVR's just don't cut it IMHO.
    A good Pre Amp/Amp/Dedicated CD and or SACD player, TT if you wish. is the only way to go..
    If I am wrong then you gurus can hang me now. But with my little experence here seperates bring the SDA's to life.
    Try a good Pre Amp and be amazed..
    AVR's suck for 2 channel!!!!
    Peace,
    Larry.
    My room is 15x18 and is defined by the fireplace and widows flanking it on either side, so the distance is set and cannot be changed. My seating distance from them is about 10 feet, but when listening I move the seat forward a couple feet and move it back when I am done.
    Peace,
    Larry.
    Agreed on the AVR.. I am actively seeking a Sunfire tube pre right now...
  • Sherardp
    Sherardp Posts: 8,038
    Looks good bro, enjoy the rig.
  • Retro152
    Retro152 Posts: 985
    Looks great John.:D:D
    Pat.
    Receiver: Pioneer Elite SC-05
    Amp: Emotiva Xpa-3
    Front L/R: POLK Rti-a9s':D
    Center:POLK Csi-a6
    Rear surround's:POLK Rti-a1s'
    Sub: Klipsch Synergy sub-12
    Sony Kdl-46w4100 46" LCD
    PS3
    Audioquest type 4 wiring.
  • comfortablycurt
    15x18!? Damn!! That's the same size as my room, and I've been having issues with my 2A's being too large for the room recently. I wouldn't even want to have the big boys in here..
    I recently hooked my Monitor 7A's back up, and I've been enjoying them a lot more than the SDA's. The 2A's were just too large for the room.
  • Conradicles
    http://www.audiogon.com/cgi-bin/cls.pl?preatube&1258131712&/Sunfire-classic-tube-preamp-re
    Bingo and just back from Rita's!!!:cool:
    and a bit to rich for my blood at the moment... I saw that one a few days ago. I am still in the bargain hunt mode.
  • leroyjr1
    For $1600 you can get a Pioneer SC-07 & Adcom gfp-750. Itll make a nice HT/music setup.
  • comfortablycurt
    leroyjr1 wrote: »
    That'd be my choice.
    The Sunfire stays! and thats my final answer. lol... I am looking for a two channel pre that I can add to my setup is all for now.
  • comfortablycurt
    With that suggestion, the Sunfire would be staying.
    Pioneer Elite SC-07=AVR
    Adcom GFP-750=2 channel pre-amp
    I'd go with a GFP-750 myself. It's main drawback is the lack of a phono stage, but it can be argued that you're better off using a separate phono stage anyway for that matter.
  • CLPolk
    CLPolk Posts: 133
    Well after reading all you went thru to get your beloved 1.2 TL's I think I would have cut 2 holes in the floor and droped them a few inches!! LOL
    • SDA SRS 2
    • SDA 1A
    • Monitor 11
    • Monitor 7B
    • CS350lsi
    • RM-6600
    • FX500i
