SDA-1B for $250?
hav a chance to grab a pair of SDA-1B in good condition for $250. Is it a good price? I need to decide fast..
Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07, logitech 880
Def Tech Mythos ST Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
Bed Room: Pioneer Elite VSX-52 , Monitor 50
Storage-RTi8,CSi5,PSW505,Monitor50
Post edited by vijayl on
I'd go for it, that's a pretty good price. They normally sell for around $350-375 from what I've seen.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I offered him lil' less and I have a feeling that I may not get it
Storage-RTi8,CSi5,PSW505,Monitor50 -
I paid $375 for my pair recently. They were in good condition but had some issues with the phantom center being way recessed. After a few weeks of steady use the center emerged, and now they sound fine. I think they needed breaking in after sitting unused in a garage for several years.
At $250 I would bother haggling too much as long as everything works and are cosmetically decent. There is a Sticky in the Vintage Speaker section with a series of listening and multimeter tests that you can easily run. There is also the "press" test: press gently on the passive bass radiator and hold it in; the mid woofers should be pushed out and gradually (2 seconds +) return to their original position. If they pop right back there is an air leak, possibly in the rubber surrounds. If there are no holes in the surrounds or cones, the drivers can be reseated with Mortite quite cheaply. If you press evenly on the mid woofers you should not hear any kind of grating noise which is the coil rubbing on the magnet (I think). (If you press unevenly, the midwoofer cone will tilt and the coil will rub.)
Good luck,
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
i didn't get these
