EQ to Amp Question
szeh
szeh Posts: 25
edited September 2009 in Car Audio & Electronics
Need some advice before I install a Clarion EQS746 to a JL Audio A6450 amp.
I want to bridge 4 channels into 2 and put out a stereo signal to two boat tower speakers. The back of the EQ has Front and Rear outs. I heard that I should come out of the Front out only of the EQ and the split with a Y adaptor just before I go into the amp. This would split the signal and give me two lefts and two rights that I need, but I've read that Y adapters suck and try not to use them.
The other method would be to use both Front and Rear outs on the equalizer. This way I wouldn't be spliting the signal with a Y adaptor, but I would be bridging the "L" signals from Front and Rear outputs and "R" from the other Front and Rear RCA plugs. I would just need to make sure my fader was at "0" on the EQ. Make sense?
Which way is best? Thanks!
Polk RTi8...Mains
Polk FXi3...Rears
Polk CSi3...Center
2-HSU STF2...Subs
Yamaha RX-V663...Receiver
Harmony One...Remote
APC H15 Power Conditioner
Samsung BD-P1500...Blu-ray
Samsung 56" HL-S5687W
Polk Atrium 50's...on the deck
Post edited by szeh on
  • MacLeod
    MacLeod Posts: 14,358
    Use the front and rear outputs of the EQ so that the amp has 4 input channels. Run the EQ left front and EQ left rear to the amp front channels and the EQ right front and EQ right rear to the rear amp channels then bridge the front channels together which will be the left, and the right channels together which would be the right.
  • szeh
    szeh Posts: 25
    MacLeod....thanks! I did just that and then set then gains with a multimeter and everything seems to be working perfectly.
    Polk RTi8...Mains
    Polk FXi3...Rears
    Polk CSi3...Center
    2-HSU STF2...Subs
  • MacLeod
    Glad to help.
