Newb question RE: Dual Binding Posts
Oblivion
Oblivion Posts: 5
Hi everyone! My first post! I've been lurking here for a while while doing some research and I finally picked up a pair of RTi A7 from Polk Direct.
My question is, Does it matter which post I connect my speaker wire to on these towers? Top or Bottom? I know they are bridged(?) already, but I just wanted to make sure I didn't mess them up, or alter the sound in some way.
I currently have them hooked up to the bottom posts, and they sound fine, although my current AVR is ancient, and slightly underpowered for these babys. I'm waiting on my Onkyo 876 sometime in the next month to rectify this problem.
Thanks in advance for any help!
Post edited by Oblivion on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited September 2009
    Welcome to Polk Forums.
    The bottom post are feeding the woofers so yes this is the best post to power up the speaker. I assume that you're using the bridge jumps between the bottom and the top post.
    BTW if you have pre amp outputs for the AVR you have now, it maybe best to add an amp to power up the front speakers. Not that the avr Onkyo 876, not that is a bad avr... But if you need more power adding an amp maybe the best update.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • danz1906
    danz1906 Posts: 5,144
    Welcome to the Club!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    treitz3 Posts: 20,207
    Just make sure that the binding strap is in place, that everything is in phase and that positive is hooked to positive and negative is to negative. If all is tight? you are good to go.
    At that point, the location of the speaker wire does not matter. Welcome to the forum.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    Looks like I am late to the party but +1 on what has been said so far. As long as the jumpers are installed it doesn't matter which set you have the wires hooked up to. Also as stated if your current AVR has pre-outs you may be best suited getting an external amp instead of the 876. Unless you are looking for a more modern AVR that does the HD sound decoding, then by all means grab the 876 it is a beast. Also, the new 807 is nothing to sneeze at either, and carries a similar price tag of around $1,000. I have an 806 and have enjoyed it for almost a year now. Welcome to Club Polk.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Oblivion
    Oblivion Posts: 5
    Thanks for clearing that up for me everyone!
    I do plan on eventually adding a power amp to run my RTi A7s in the front, but for now I'm building it out into a 5.0 system by adding an CSi A4 in the center, and probably a pair of Fxi A4s in the back. Like I said, my current AVR is inadequate for this job, so I will be getting the Onkyo 876 in the near term, then adding a subwoofer and power amp to the mix later.
    Anyone have any suggestions on a good power amp to run the RTi A7s?
    Anything with a tube ;). Got a budget in mind?
  • Oblivion
    Oblivion Posts: 5
    Not much more than a few hundred, If that can get me at least 200wpc of good clean power for my RTi A7s. I might be willing to spend a little more.
    I admit, I haven't done much research on 2 channel power amps recently, so I'm kinda clueless about performance/price comparisons. Any ideas would be much appreciated!
  • Retro152
    Retro152 Posts: 985
    Oblivion wrote: »
    You will have to hit the used market of course, with that budget in mind. That not being a bad thing at all, great deals can be had. Rotel, Sunfire, Adcom, Nad, Parasound, to name a few. For now, i would try to get my hands on that Onkyo 876 as soon as possible, and save some cash for an amp later. Your current AVR, you describe as "Ancient" could do some serious damage to your speakers, not offering up enough power.
    Pat.
    Receiver: Pioneer Elite SC-05
    Amp: Emotiva Xpa-3
    Front L/R: POLK Rti-a9s':D
    Center:POLK Csi-a6
    Rear surround's:POLK Rti-a1s'
    Sub: Klipsch Synergy sub-12
    Sony Kdl-46w4100 46" LCD
    PS3
    Audioquest type 4 wiring.
  • quadzilla
    quadzilla Posts: 1,543
    I'm going to be the dissenter and say that when I moved the cables to the top posts, I got a bit more clarity and high-end extension. Not a huge difference, but noticeable. The cheap gold-plated brass those jumpers are made from smear the signal a bit. I ended up replacing them with short sections of speaker wire until I started bi-amping.
    I like my Mackies, but am in the process of modding them because I find the fans annoying when listening at very low levels. I think I can make them pretty quite for another 20 bucks or so, and a little time/effort. Anyway, you might think about those for your power amp. You can pick up Mackies in good shape off flea-bay for around 2-250 shipped. An FR800 is probably about what you need.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    i have mine set-up so that the wire goes to the bottom half first and then i ran a small section of wire connecting to the top post's, should i remove the brass jumper's?
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • disneyjoe7
    If you added a wire between the top 2 post to the bottom 2 post red to red, black to black you don't need the brass jumpers these should be removed now.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • sTiLlLeArNiNg
    disneyjoe7 wrote: »
    will do! thank's :D
    Would it alter the sound in any way? i'm assuming yes since there would be less resistance :confused:
    Media Room 7.1
    HTPC
  • disneyjoe7
    I think you can hear the difference for sure. :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • ben62670
    ben62670 Posts: 15,969
    I like Adcom's or Parasound's in that budget. A watt is not a watt. The Adcom GFA-545 is only rated at 100wpc 8 ohms, and it will spank just about any receiver you find in a store.
    Ben
  • sTiLlLeArNiNg
    disneyjoe7 wrote: »
    OH MAMMA! it's like i got new speaker's!! :D and i'm just using some rocketfish 16g wire lol
    i definately reccomend this (pulling the flat metal connector and running a small jumper) to anyone with dual binding post's on their speaker's :D
    Media Room 7.1
    HTPC
  • michaeljhsda2
    michaeljhsda2 Posts: 2,206
    Cool. :) I'm never going to biamp my 1.2 TL's so I got rid of mine altogether and just combined them on the inside. I'm using the top posts for the interconnect cable.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • sTiLlLeArNiNg
    ^^ WOAH that look's confusing! :o
    Media Room 7.1
    HTPC
  • disneyjoe7
    Amazing what a wire can do :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • sTiLlLeArNiNg
    disneyjoe7 wrote: »
    tell me about it! :D it will be interesting to hear the difference when i switch to a better cable altogether later on down the road :cool: as it is right now they sound more "alive" if that make's sense
    i think Polk should save themselve's the cash and do away with those jumper's completely and include instruction's on how to do basic wire hook-up :)
    Media Room 7.1
    HTPC
  • shooter313
    shooter313 Posts: 3
    This was TRUELY a great thread.:) I am kind of new to this high end stuff, and I never knew about the wire connections as described above. I just assumed that the metal bridges were all that would ever be needed on my polks. First thing in the AM I am going to follow the above suggestions and rewire all of my speakers.
    Thank you all VERY MUCH for taking the time to give out this information, it is a GREAT help to people like myself.:D
    Shooter313===>>
  • sTiLlLeArNiNg
    N/P shooter! I'm pretty new to this stuff myself and was REAL skeptical at first but it really made a difference! :D
    I'm not shure but i think the jumper bar's add to much resistance and "muffle" the sound :confused:
    Media Room 7.1
    HTPC
  • pablo_rodz
    pablo_rodz Posts: 331
    Jump on this amazing deal, 10 gauge Acoustic Research wires. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=109-064 I got it and was amazed by the results. I'm NOT running any amps., just straight to the receiver.
    The low's on my RTi 10's came alive! very clear sound compared to the 14 ga. Audio Quest speaker wires I was using.
    HT:
    Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
    Living Room:
    Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
  • michaeljhsda2
    pablo_rodz wrote: »
    jump on this amazing deal, 10 gauge acoustic research wires. http://www.parts-express.com/pe/showdetl.cfm?partnumber=109-064 i got it and was amazed by the results. I'm not running any amps., just straight to the receiver.
    The low's on my rti 10's came alive! Very clear sound compared to the 14 ga. Audio quest speaker wires i was using.
    +1,000,000
    SDA SRS 2.3TL's
    SDA 2B TL's
