Denon AVR-4810CI versus AVR-4308CI
Bernal
Bernal Posts: 991
edited March 2014 in Electronics
Hello.
Denon AVR-4810Ci: Next Generation 9.3 CH A/V Home Theater/Multimedia Multi-Source/Zone Receiver with Network Streaming and WiFi.
It's the same AVR-4308Ci.
http://www.usa.denon.com/AVR4810CI_Large_Front.jpg
http://www.usa.denon.com/AVR4810CI_Large_Back.jpg
http://www.usa.denon.com/ProductDetails/257.asp?compareitem=5118&compareitem=3494&imageField.x=86&imageField.y=19
Post edited by Bernal on
  • Bernal
    Bernal Posts: 991
    edited September 2009
    Once again, Denon advances the state-of-the-art in home theater surround sound with the AVR-4810CI, with nine on-board amplifier channels each rated at a robust 140 watts. The multi-mono block amp construction ensures top audio fidelity, and the Free Assign amp configuration function allows maximum system configuration flexibility. Equipped with the latest high resolution audio decoders including Dolby TrueHD and DTS HD Master Audio, the AVR-4810CI also features Dolby Pro Logic IIz, which derives additional front height channels. The AVR-4810CI also features a full suite of advanced Audyssey sound processing functions, including MultEQ XT eight point room acoustic measurement and correction, Dynamic Volume and Dynamic EQ, as well as the latest DSX decoder, which provides additional expanded front width and/or height channels. Any video signal, analog or digital, can be upscaled to 1080p HDMI output via Anchor Bay’s advanced VRS processing, and the AVR-4810CI includes vertical stretch mode for anamorphic 2.40:1 widescreen projection. The AVR-4810CI also features extensive audio and video connectivity, including six HDMI and three component video inputs. The dual AM/FM tuner section includes HD Radio, and the AVR-4810CI features XM and Sirius satellite radio options.
  • Bernal
    Bernal Posts: 991
    I see that the AVR-4810CI is already listed on Denon's website, and the AVR-4308CI are talked about on C-Net and other web sites. It looks like the 4810 and 4308 are $2999 and $2699 MSRP.
    The specs look nice - 5 HDMI inputs and 2 HDMI outputs on the 4810, Pro Logic IIz/Audessey DSX height decoding, Anchor Bay 1080P upconversion, etc. It looks like it would be a killer pre-pro, but the lighter weight has me concerned about the amplifier performance.
    Has anybody gotten their hands on either of these?
    Please post as soon as anyone gets a chance to use one of these.
    :rolleyes:
  • vijayl
    vijayl Posts: 258
    Its WiFi has .11b, g which is not good enough for the HD (MP4) streaming.
    Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07
    , logitech 880
    Def Tech Mythos ST :D Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
    2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
    Bed Room: Pioneer Elite VSX-52 , Monitor 50
    Storage-RTi8,CSi5,PSW505,Monitor50
  • Bernal
    Bernal Posts: 991
    vijayl wrote: »
    It's the same AVR-4308Ci.:rolleyes:
  • BB3
    BB3 Posts: 297
    Bernal,
    For the little difference in cost between the two, it is most certainly worth going for the 4310 just to get the far superior processing power of Anchor Bays VRS chip.
    The Faroudja DCDi chip used in the 4308 leaves alot to be desired with its very limited processing capabilities.
    So in summary, and not even counting the other upgrades that the 4310 possesses over the 4308, the 4310 is worth the price of admission over the 4308 just for, and to get that Anchor Bay VRS processing chip. Period.
    Just my thoughts Bernal. Take Care.
    BB3
    Sony 52in.XBR6
    Sony 32in.XBR6
    Anthem AVM50V
    Anthem PRE-2L
    Sonic Frontiers SFCD-1
    Carver C-9
    Carver C-19 PreAmp
    Carver C-16 PreAmp
    2-Carver Silver 7-T's
    4-Carver TFM55's
    2-Carver TFM35's
    1-Carver TFM25
    Carver 490T
    Denon DCD1560
    Sony BDP-S350
    Sony PS3
    Nintendo Wii
    Panasonic DMK23DVR
    Speakers :
    PolkAudio SDA-SRS
    PolkAudio SDA-SRS 1.2TL
    PolkAudio SDA-CRS+(Compliments Of Mr. Jim Thomas"jtgranby")
    PolkAudio RTA-15TL
    PolkAudio M3
    3-Velodyne F-1500's
  • Bernal
    Bernal Posts: 991
    BB3 wrote: »
    Bernal,
    BB3
    BB3,
    Thanks for your reply.
    I have the "OPPO BDP-83 Blu-ray Player" that comes with: VRS™ by Anchor Bay - The BDP-83 incorporates Anchor Bay's award-winning Video Reference Series (VRS).
    If you disable Farouja 4308 and go straight. Even so worth a higher value...
  • Bernal
    Bernal Posts: 991
    Subject
    AVR4308Ci versus AVR4810Ci. I can help. AVR4308Ci: I want to upgrade. I get a...
    Discussion Thread
    Response (Ean Levy) - 09/10/2009 05:17 PM
    With the 4810 you get a 9.3 receiver instead of a 7.1 receiver. Dolby PL IIz Audyssey DSX Denon Link 4 Napster streaming
    Customer (Bernal) - 09/10/2009 12:39 PM
    AVR4308CI versus AVR4810Ci.
    I can help.
    AVR-4308 and I want to upgrade.
    I get any benefit of going to AVR-4810?
    Auto-Response - 09/10/2009 12:34 PM
    These Answers were automatically selected for your consideration. If your issue is addressed in our public Answers, the solution link should be listed below. If no solutions are listed or the solutions do not match your issue, there were no public Answers matching your issue.
    Your request has not yet been submitted. Select "Submit Request" to submit your issue to our support staff.
    Title: Are there upgrades or updates for my Denon product?
    Link: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_adp.php?p_faqid=100&p_created=1187357391
    Title: How do I update the firmware on my AVR-3808CI, AVR4308CI receiver?
    Link: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_adp.php?p_faqid=207&p_created=1190993615
    Title: Do I always have to "toggle" or "page through" the entire menu with the On-Screen Display Button, even if I only want to see the first page?
    Link: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_adp.php?p_faqid=63&p_created=1187275353
    Title: Why can't I change DSP modes or turn "Cinema EQ" on (or off) while I'm using the on-screen menu?
    Link: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_adp.php?p_faqid=76&p_created=1187279828
    Title: Where can I download an Owner's Manual for my Denon Product?
    Link: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_adp.php?p_faqid=22&p_created=1187188103
    Customer (Bernal) - 09/10/2009 12:34 PM
    I can help.
    AVR4308Ci: I want to upgrade. I get any benefit of going to AVR4310Ci?
    Question Reference #090910-000067
    Product Level 1: AV Receivers
    Product Level 2: AVR-4308CI
    Category Level 1: Updates and Upgrades
    Date Created: 09/10/2009 12:34 PM
    Last Updated: 09/10/2009 05:17 PM
    Status: Complete
    Model #: AVR-4308CI
    Serial # (optional):
    00
    2nd Model #:
    Dealer :
    Denon Dealer: Other
    Denon Dealer Other :
    Dealer Location
  • Bernal
    Bernal Posts: 991
    :rolleyes: Denon 4308Ci
  • Bernal
    Bernal Posts: 991
    edited October 2009
  • Unknown
    edited March 2014
  • Sorry_Access_Denied
    edited May 2021
    BB3 wrote: »
    Bernal,
    BB3
    Yeah, that’s great but he was talking about the difference between the AVR-4308 and the AVR-4810, not the 4310. The 4310 isn’t an upgrade to the 4308, it’s an upgrade to the 3808.
    pitdogg2 Posts: 27,335
    Beating a very dead horse here. Both are now considered antiques.
