Anyone Using ReadyBoost?
I-SIG
Just found out about the ReadyBoost feature of Vista after I plugged in a 2GB high-speed (mine is 133x; 20Mbs read/write sustained; class 6 for SDHC) SD card into the slot. I bought 3 of these for my new camera. Pretty neat.
I'm not sure how much a difference it will make since it is only a 2GB device and I have 4GB of DDR3 1066Mhz memory, but it certainly can't hurt I figure. I did read that it compresses the data on a 2:1 ratio, so in that sense I'm at 1:1 as recommended, but....
Wes
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
are you running the 64 bit version of vista?TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
Oh yeah.
No other sensible way to get Vista if you can't use the RAM already installed, much less anything on a flash drive.
I checked my Event Viewer and the card tested at a random read speed of 8867 kb/s and sequential write speed of 10205 kb/s.
On an unrelated note, ESPN360 says it's not compatible with 64-bit systems but it worked great this weekend on my machine.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
I had to ask I see time and time again people putting 6 and 8gb of ram in there pc running a 32 bit OS. from my experience with readyboost the improvement wasnt enough to be worth it. I gained .2 points on my windows experience rating. My pc didnt boot any faster and with you having 4gb of ram I dont think your sytem would ever need to use the readyboost but im sure it doesnt hurt to have if it does need it.TV: Philips 42" LCD 1080p
AVR: Denon 3801
Sat: Directtv HD 10
when i first was running vista i was using 1gb ram, the readyboost 4gb usb stick really made a difference... since then i have installed a ssd OS drive and now 2gb ram on vista 64 and i'm not sure if ready boost is as huge of an improvement as it used to be, but the light on my usb stick sure does flash a lot still, maybe its still working alot and i dont notice. doesn't cost much to store your usb stick in a usb port and just disable ready boost when you need portable data.
if you're looking for a low cost upgrade read anandtech.com's write up on ssd drives and consider using one for your operating system drive.________________________________
Panasonic TH-50PZ800U; Sony BDP-S350
Sony STR-DA5400ES; Carver TFM-55
Carver TFM-35; Carver A-500x
Sony Playstation 3; Custom HTPC
Polk Monitor 10B Front; 2xPolk CS350LS Center;
Monitor 5B rears (RB0194-1 Upgrade);
Velodyne VA1012XII sub
