To all carver amp owners:
royalty
On my tfm-35 theres a range button and when I hit it once the needle that shows the watts being used and such is much more active. When I hit it again its back to being less active. Is the less active one showing the big range of watts and the more the small range or do I have it backwards or completely wrong?
HOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
Post edited by royalty on
Usually one setting is for low volume perhaps 1 to 10 watts, then the other setting is for 10 to 250 watts or some variation on that. It's really so that you can watch the needles jump even at low volume. My Kenwood KA-9100 has range 1 to 10 watts and then 10 to 120 watts. My TFM-25 has no range adjust.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Most people just like watching the needle just, but it would be very helpful if you were testing the output of the amp at 1 watt or something like that were you needed to see that number.
One setting shows the power at 1/10 and the other shows at true level. If you listen to your amp at low levels and like to see the needles jump around then push in the button.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
